@dt-lib this has been very odd. In the time you spend claiming you didn’t add the alert rules, you could have deleted/disabled them 20 times over.
You control your instance. Just remove the rules, please.
I’m trying to understand the alerts instead of just disabling them.
I stated they are global/default then @laf tells me there are no global/default rules. In his next post he contradicts himself and says there are rules if you clicked the button.
Then I ask how to fix two alerts, 1 is a reboot alert (how do you fix a reboot alert)? 2 is a port utilization at 80%, which I don’t have any ports on that device that are at 80%.
I’m trying to learn and help explain the issue I’m having.
Do you want to help? Great, what can I do?
If you don’t want to help and simply reply with telling me to disable them, then please delete this post.
