After update to 22.8.0 it is impossible to delete group from port any more, log prints this SQL error:
[2022-08-21T01:36:09.298593+03:00] production.ERROR: SQLSTATE[23000]: Integrity constraint violation: 1452 Cannot add or update a child row: a foreign key constraint fails (`librenms`.`port_group_port`, CONSTRAINT `port_group_port_port_group_id_foreign` FOREIGN KEY (`port_group_id`) REFERENCES `port_groups` (`id`) ON DELETE CASCADE) (SQL: insert into `port_group_port` (`port_group_id`, `port_id`) values (0, 36725289)) {"userId":8,"exception":"[object] (Illuminate\\Database\\QueryException(code: 23000): SQLSTATE[23000]: Integrity constraint violation: 1452 Cannot add or update a child row: a foreign key constraint fails (`librenms`.`port_group_port`, CONSTRAINT `port_group_port_port_group_id_foreign` FOREIGN KEY (`port_group_id`) REFERENCES `port_groups` (`id`) ON DELETE CASCADE) (SQL: insert into `port_group_port` (`port_group_id`, `port_id`) values (0, 36725289)) at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:712)
[previous exception] [object] (Doctrine\\DBAL\\Driver\\PDO\\Exception(code: 23000): SQLSTATE[23000]: Integrity constraint violation: 1452 Cannot add or update a child row: a foreign key constraint fails (`librenms`.`port_group_port`, CONSTRAINT `port_group_port_port_group_id_foreign` FOREIGN KEY (`port_group_id`) REFERENCES `port_groups` (`id`) ON DELETE CASCADE) at /opt/librenms/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDO/Exception.php:18)
[previous exception] [object] (PDOException(code: 23000): SQLSTATE[23000]: Integrity constraint violation: 1452 Cannot add or update a child row: a foreign key constraint fails (`librenms`.`port_group_port`, CONSTRAINT `port_group_port_port_group_id_foreign` FOREIGN KEY (`port_group_id`) REFERENCES `port_groups` (`id`) ON DELETE CASCADE) at /opt/librenms/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php:117)"}
