26.8.0
(2026-08-17)
A big thank you to the following 34 contributors this last month:
- murrant (59)
- laf (8)
- dependabot (8)
- remum32 (7)
- eskyuu (5)
- Jacke1012 (3)
- SourceDoctor (3)
- Jellyfrog (2)
- peejaychilds (2)
- Starson323 (2)
- VVelox (2)
- bennetgallein (1)
- dj1079 (1)
- mehdiMj-ir (1)
- marcinpsk (1)
- MarlinMr (1)
- takyanagida (1)
- Fever-Wits (1)
- bakerds (1)
- mib1185 (1)
- whyaminotsurprised (1)
- mateo08c (1)
- L8SE (1)
- J-cztery (1)
- rjvannugteren (1)
- fauust (1)
- ra1do (1)
- jasoncheng7115 (1)
- weberc (1)
- ovi82 (1)
- MelonicOverlord (1)
- Yoyasp (1)
- shward (1)
- Npeca75 (1)
- laf (35)
- murrant (32)
- Jellyfrog (11)
- PipoCanaja (1)
- eskyuu (1)
Feature
- Add timestamps to the daily.sh script (#20309) - bennetgallein
- Missing query string validation (#20302) - murrant
- Alert macro for device average CPU utilization (#20275) - murrant
- Add FDB and ARP to global search (#20240) - murrant
Security
- Update 2fa creation and checking (#20320) - laf
- API tokens must have existing enabled user (#20304) - murrant
- Escape mpls pages html (#20229) - murrant
- Unix agent include prevent .. (#20225) - murrant
- Escape graph parameter strings (#20221) - murrant
- API tokens use strict types (#20220) - murrant
Device
- Add transceivers, unit temperature, and vlan trunk info to Cisco SB (#20261) - takyanagida
- Fix ASA VPN load-balancing sensors always polling as 0 (#20253) - remum32
- Add ‘Catalyst 1300X Series’ to
ciscosb(#20250) - mib1185 - Fix false stack alerts on standalone Huawei S5720 devices (#20245) - Starson323
- Add complete Dell OS10 PSU status mappings (#20237) - whyaminotsurprised
- Don’t gate AP inventory polling on ap-count sensor existence (#20236) - mateo08c
- Remove low-value clogNotificationsSent syslog sensor (ios/iosxe) (#20235) - remum32
- Add CISCO-SYSLOG-MIB message counters (ios/iosxe) (#20233) - remum32
- Add PanOS ICMP session and GlobalProtect gateway utilization sensors (#20217) - remum32
- Add third LambdaTrail hardware variant support (#20197) - remum32
- Add APC InRow RC (ACRC1xx) cooling unit monitoring support (#20191) - remum32
- Add Cisco ASA VPN load-balancing (LBSSF) monitoring (#20171) - remum32
- Update Sophos XG with current MIB file, new sensor data and new logos (#20133) - weberc
- Add Rittal IoT Interface detection (#20125) - Jacke1012
- Add support for CTS devices HES-5106 / ESW-5112 (#20119) - ovi82
- Extreme VOSS - IS-IS Adjacency Discovery (#20099) - MelonicOverlord
- Fix entPhysicalIndex / inventory / empty SFP slots for mes24xx devices (#18057) - Npeca75
Webui
- Fix an issue with dynamic loading for geomap (#20301) - murrant
- Increase Map height on Device Overview (#20300) - SourceDoctor
- Restore device map functionality (#20289) - murrant
- Fix alert count and change style (#20270) - murrant
- Uncollapsecount fix (#20262) - SourceDoctor
- Format frequency values with SI prefixes (#20259) - Fever-Wits
- Modernize access points device tab (#20239) - Jacke1012
- Allow BGP peer to match any device IP, not just the Peer Identifier (#20231) - Starson323
- Restore the ability for global searches on Cisco MAC address format (#20209) - eskyuu
- Server stats widget: hide gauges (#20208) - murrant
- Remove bottom margin on device summary widgets (#20199) - murrant
- Config backup line numbering/highlighting tweaks (#20195) - murrant
- Add ability to skip custom oid tests for distributed pollers (#20194) - laf
- Fix server stats widget issues (#17721) (#20193) - L8SE
- Device config refresh (Oxidized and Unimus) (#20192) - laf
- Filter bar fix saved filters (#20190) - murrant
- Include filter in table export (#20188) - murrant
- Reduce widget header size (#20184) - murrant
- Add configuration options to control what is included in the global search (#20175) - eskyuu
- Config Backups: highlighting and line numbers (#20173) - murrant
- Rewrite device overview (#20172) - murrant
- Font size should actually be 14px (#20170) - murrant
- World Map Widget: try to zoom to fit on first load (#20164) - rjvannugteren
- Fix top interfaces widget popups (#20159) - murrant
- Fix some sizing issues (#20158) - murrant
- Reduce device maintenance check queries (#20147) - murrant
- Remove left over body padding (#20142) - murrant
- Config backup page improvements (#20129) - murrant
- Alerts table to Laravel (#20120) - murrant
- Add count to Alerts menu nav showing active alerts (#20117) - laf
- Reset font size to 16px (#19983) - murrant
Alerting
Graphs
- Graph autosizing improvements (#20271) - murrant
- Fix graph issue when no device is found for device graph (#20256) - murrant
Applications
Api
- API v1 refinements (#20284) - murrant
- Fix port_stack API docs to match the current response (#20274) - marcinpsk
- Use Eloquent in location APIs (#20226) - murrant
- Fix oxidized permissions, add oxidized.list (#20181) - murrant
- Restore logs apis (#20174) - murrant
- API permissions (#20139) - murrant
- Add initial restify API (#19911) - Yoyasp
Discovery
- IPv6 ND store MAC normalized (#20252) - murrant
- Discover new/rediscover devices sooner (#20148) - murrant
Authentication
Bug
- Fast ping snmp toggle fix (#20313) - murrant
- Fix undefined stack variable in NTP graphs (#20303) - Jacke1012
- Override Restify Policy command to fix upstream issue (#20299) - murrant
- SNMP infer encoding (#20292) - murrant
- Fix DB query statistics being off by a factor of 10 (#20273) - peejaychilds
- Add Outcome.EXCLUDED mapping to fix KeyError (#20267) - MarlinMr
- Only count detail characters not rendered onces (#20200) - SourceDoctor
- New command dev:collect-snmprec (#20196) - murrant
- Allow vrfs.mplsVpnVrfDescription to be null (#20185) - J-cztery
- Fix alert widget uncollapse setting (#20161) - murrant
- Snmp-scan.py fix usage on newer python (#20160) - murrant
- Fix LLDP remote_hostname carry-over when lldpRemSysName is empty (#20141) - ra1do
- Remove python dependency check from daily.sh (#20107) - murrant
- Standardise device rename operations and fix duplicate hostname check during rename (#19998) - eskyuu
Refactor
- Resolve issues with slow global device search queries (#20176) - eskyuu
- Migrated Oxidized to new Device Config Backup code (#20116) - laf
- Convert snmp_get to SnmpQuery::get for apps (#18059) - VVelox
Cleanup
- Suppress deprecation errors (#20288) - murrant
- Include exception class in per-module eventlog messages (#20282) - peejaychilds
- Fix SQL queries using && in RunAlerts.php (#20201) - murrant
- Refactor device search to use whereRelation() instead of whereIn() (#20180) - eskyuu
- Optimize plugin loading (#20154) - murrant
- Optimize application observers boot (#20153) - murrant
- Replace graph.php links (#19994) - murrant
Documentation
- Rewrite documentation in Simplified Technical English (#20296) - Jellyfrog
- Fix libreNMS installation documentation on Ubuntu server 26.04 (#20278) - mehdiMj-ir
- Fix typo and improve consistency of JSON formatting (#20255) - bakerds
- Bump minimum PHP version to 8.4 (#20244) - Jellyfrog
- The docker container use MariaDB not MySQL (#20155) - fauust
Translation
- Update Traditional Chinese (zh-TW) translations for 26.7.0 (#20136) - jasoncheng7115
Tests
Misc
- Update installation documentation for RHEL-like OS (#20308) - dj1079
- Smarter loading for plugins (#20287) - murrant
- Fix OID prefix matching and output format (#19651) - shward
Internal Features
Dependencies
- Bump league/commonmark from 2.8.3 to 2.9.0 (#20248) - dependabot
- Bump fast-uri from 3.1.4 to 3.1.5 (#20230) - dependabot
- Update PHP dependencies and add tooling scripts (#20198) - murrant
- Bump postcss from 8.5.15 to 8.5.23 (#20165) - dependabot
- Bump fast-uri from 3.1.2 to 3.1.4 (#20145) - dependabot
- Bump immutable from 5.1.5 to 5.1.9 (#20144) - dependabot
- Bump guzzlehttp/guzzle from 7.13.0 to 7.15.1 (#20126) - dependabot
- Bump composer/composer from 2.10.1 to 2.10.2 (#20124) - dependabot
- Bump axios from 1.16.0 to 1.18.0 (#20123) - dependabot
