Active Directory LDAP authentication is not working
hello everyone,
This is my first ever post and I’m little anxious…so please help if possible…
My active directory LDAP authentication stopped working couple of weeks ago and I’m struggling to find what had happened. I have enabled daily and automated updates of stable release.
-bash-4.2$ whoami
librenms
-bash-4.2$ pwd
/opt/librenms
-bash-4.2$ ./validate.php
LibreNMS 1.44
DB Schema 268
PHP 7.1.17
MySQL 5.5.56-MariaDB
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
[OK] Composer Version: 1.7.2
[FAIL] Missing PHP extension: mysqlnd
[FIX] Please install mysqlnd
test auth script works ok
-bash-4.2$ ./scripts/auth_test.php -v -d -u xxx
Authentication Method: ldap
Password:
Authenticate user xxxx:
AUTH SUCCESS
User (1200402):
Groups: Array; cn=xxx,OU=Manual,OU=Distribution Lists,DC=xx,DC=xx,DC=xx,DC=xx; cn=xxx,OU=Manual,OU=Distribution Lists,DC=xx,DC=xx,DC=xx,DC=xx
-bash-4.2$
In web UI after providing username/password i cant get to dashboard … it says following in logs/librenms.log
[2018-10-25 17:24:32] production.ERROR: Auth Error (ldap): No user (1200402) [xxx]
here is my LDAP config in config.php
// Authentication Model
$config[‘auth_mechanism’] = “ldap”; // default, other options: ldap, http-auth, please see documentation for config help
$config[‘auth_ldap_kerberized’] = TRUE;
$config[‘auth_ldap_version’] = 3;
$config[‘auth_ldap_server’] = “ACTIVE DIRECTORY HOST”;
$config[‘auth_ldap_port’] = 389;
$config[‘auth_ldap_starttls’] = “require”;
$config[‘auth_ldap_binddn’] = “CN=xxx,OU=Functional_IDs,DC=xx,DC=xx,DC=xx,DC=xx”;
$config[‘auth_ldap_bindpw’] = “XXX”;
$config[‘auth_ldap_bindanonymous’] = FALSE;
$config[‘auth_ldap_prefix’] = “CN=”;
$config[‘auth_ldap_suffix’] = “,OU=xxx,DC=xx,DC=xx,DC=xx,DC=xx”;
$config[‘auth_ldap_attr’][‘uid’] = “sAMAccountName”;
$config[‘auth_ldap_attr’][‘uidNumber’] = “objectSid”;
$config[‘auth_ldap_attr’][‘cn’] = “name”;
$config[‘auth_ldap_objectclass’] = “person”;
$config[‘auth_ldap_groupbase’] = “OU=Manual,OU=Distribution Lists,DC=xx,DC=xx,DC=xx,DC=xx”;
$config[‘auth_ldap_group’] = array(“CN=xxx,OU=Manual,OU=Distribution Lists,DC=xx,DC=xx,DC=xx,DC=xx”, “CN=xxx,OU=Manual,OU=Distribution Lists,DC=xx,DC=xx,DC=xx,DC=xx”);
$config[‘auth_ldap_groupmembertype’] = “fulldn”;
$config[‘auth_ldap_groupmemberattr’] = “member”;
$config[‘auth_ldap_debug’] = true; // enable for verbose debug messages
$config[‘auth_ldap_userdn’] = true; // Uses a users full DN as the value of the member attribute in a group instead of member: username. (it’s member: uid=username,ou=groups,dc=domain,dc=com)
unset($config[‘auth_ldap_groups’]);
$config[‘auth_ldap_groups’][‘xxx’][‘level’] = 10;
$config[‘auth_ldap_groups’][‘xxx’][‘level’] = 5;
Many thanks,
What isn’t working login? Userlevel? API?
Have you thought of using AD authentication? That’s what we are using…
$config[‘auth_mechanism’] = ‘active_directory’;
Web UI login…
thanks. AD authentication works flawlessly… Cheers
Can you please explain little more about as I am also having issue with my loging?
root@abdulwpk:/opt/librenms/scripts# ./auth_test.php -u abdul
Password:
Authenticate user abdul:
Error: LibreNMS\Exceptions\AuthenticationException thrown!
Success
I’m having the same issue. @Abdul_Wahab have you found any fixes?
Thanks,
J
I have still not found any solution for this. have you found any solution?
