gonzo
1
Hello, I’m trying to configure AD authentication and it’s not working on first attempt. I added my config to config.php and saved.
If I add the below config I can’t log in with AD credentials or Local until I remove or # these lines.
Can you see anything wrong with this?
https://pastebin.com/2qGZyQMZ
I would comment all that all out from config.php and use the Web UI now. It’s all under Settings ->Authenication
gonzo
3
When I enter it all on the GUI will it automatically stop using the local users?
Is there a way to debug why it fails?
gonzo
5
Is there a specific log for ad auth?
In looking @ the raw file. your SSL is set to false. if your AD Server only allows secure lookups you need to set this to true.
system
Closed
7
