COMPLETE: Add chown and validate.php to daily.sh
Sorry if this sounds like it’s coming from a position of ignorance, but we just started testing librenms.
I noticed after I run ./validate.php it almost ALWAYS says that my local git is out of date, and recommends and update.
When I run ./daily.sh it downloads some stuff, but I have to run the chown command to fix the permissions.
On my daily.sh I added (and call) a function to set the permissions afterward, and then to again call .validate.php.
This seems to work for me, but when I run it, it gives me another warning because I’ve had locally edited files and says
I’m curious if there’s a way this type of functionality could be added daily.sh to allow it to be done in a single command?
Thanks in advance…
I included my code below, but mine is just junky ‘Works for me’ code.
set_ownership(){
status_run “Updating Ownership” “chown -R librenms:librenms /opt/librenms”;
main "$@"
set_ownership
./validate.php
This pull request is working towards stopping you running daily.sh as a non-librenms user.
I’m not sure we should run chown automatically as people are free to customise their installs.
However the short of this, when you are in /opt/librenms - be the librenms user rather than anyone else, especially root.
If you run ./daily.sh as the librenms user, you will not have to fix permissions afterwards.
It tells you your git is out of date because it is, but this is only a warning. It also prints a date, if this is within the last day, everything is working fine. Things get merged upstream almost every day during the week.
We cannot add chown to the daily.sh script because:
a) it is run by the librenms user, so this will fail. (It works for you because you are running it as root)
b) not all users run librenms as a dedicated users, although this should be almost none hopefully
I may have an idea to allow you to run ./daily.sh as root, but please run it as the librenms user for now.
Thank you both for the replies. I will change the way I’m running the daily.sh. I just happened to be sudo’d when I ran it because I was still setting it all up. I won’t do it again :slight_smile:
Murrant,
what are you thinking?
Already done. daily.sh uses su if applicable.
ah, Okay, I knew you added that, I wasn’t sure if you were talking about anything else
COMPLETE:
LibreNMS is already taking care of changing the user to librenms when needed.
