Add Device Via ICMP
I noticed the recent change in the Device Add UI (Looks Better), however adding devices via ICMP no longer works. The discovery of a new device via ICMP never completes.! The other the thing we’ve noticed is the ability to select a OS from a dropdown menu is no longer available.
What happened.?
Version: 26.11.0-dev.45+b3b2822d1b - Sat Oct 24 2026 19:58:53 GMT-0500
Database Schema 2026_10_04_000000_update_device_polling_methods_check_columns (417)
Web Server Apache/2.4.62 (Red Hat Enterprise Linux) OpenSSL/3.5.8
PHP: 8.4.27
Python: 3.9.25
Database MariaDB 10.5.29-MariaDB
Laravel: 12.69.3
RRDtool: 1.7.2
Net-SNMP: 5.9.1
What do you mean discovery never works?
Icmp only devices never have discovery…
Manual OS override still exists.
After adding a device, it never gets past the following, and what happened to the OS dropdown menu.?
This device has not been discovered yet. This page will refresh automatically when discovery completes.
Just to be clear the UI for adding devices is completely different than what we have used in the past, no big deal, git update lots of things change over time. The UI looks better but adding device using ICMP doesn’t work. The only way I’m able to get to work with a new device is via the cli.
For example, adding a VIP called testing.abc.com for the purpose of validating certificate validity.
./lnms device:add --ping-only testing.abc.com
After adding and selecting “3com” os:
