This might already exist but I’d love to be able to add the port description to the dBm page under the health section. Is this a valid request or did I miss something in the documentation?
Hi
It does not exist yet. Request makes sense. But you also have to know that this can only work if libreNms has a way to figure which sensor is attached to which interface. This is not the case with every type of device. Some vendors do not provide a proper mapping between both.
That’s disappointing. It seems pretty simple to be able to check a column to make that appear.
