Hi all,
I’m trying to add the same device twice into librenms, and I’m not able to do so (I guess thats by design).
My use case for it is a cluster system:
- add both cluster nodes for monitoring CPU, Mem, FS, … - all system specific data.
- add an additional “system” to monitor services, which are implemented virtually. (monitoring IP is a virtual IP, which can move between cluster nodes)
For the services I want to have one statistic for i.e. traffic volume, independent of underlying physical system. - this could be done by accessing the virtual IP.
Is there any method, to implement this?
Thanks,
Philipp
