We are interested in monitoring for supervisor. We would like monitoring on the state of the processes. That way we can add alerts if for instance a process goes in state “FATAL”.
How would I go about adding this to LibreNMS? I currently have the client code ready which outputs something like this:
“version”: 1,
“error”: 0,
“errorString”: 0,
“data”: {
“api_version”: “3.0”,
“supervisor_version”: “3.4.0”,
“processes”: [
“name”: “consumers-default_00”,
“group”: “consumers”,
“statename”: “RUNNING”,
“state”: 20,
“error”: null,
“start”: 1641897745,
“stop”: 1641897744,
“now”: 1641898092,
“uptime”: 347
“name”: “consumers-default_01”,
“state”: 20,
“error”: null,
“stop”: 1641897744,
“now”: 1641898092,
“uptime”: 347
The main issue I am facing atm is that the most interested part is the actual state. Ideally this is a string. I believe LibreNMS only stores numbers, so this is a problem.
I also wonder if it is possible to show instead of graph maybe a table? I haven’t come across examples of this.
Or what should this graph look like to clearly show the status of each process.
Quickest way would be to write a script that accepts -H HOSTNAME args and then outputs in a nagios check script format and response code then use the service checks to call it.
These are the expected status codes the script should return:
[0 => ‘OK’, 1 => ‘Warning’, 3 => ‘Unknown’]
It can also record performance data from the output but you’ll need to check the code to understand how to use that.
