Added Dry Contact Sensors and Relay to geist-watchdog.yaml
I have modified the geist-watchdog.yaml to include the additional onboard sensors and relay (ie 4 dry contact sensors and 1 relay).
I have 2 questions:
  1. Where do I submit this discovery file for review and editing so it can be added to LibreNMS? I am a complete newbie, I also noticed that libreNMS is trying to graph these sensor even though they are an open/closed sensor.
  2. I’d like the ability to label these sensors and their states within the GUI because they will monitor different things for different users. I assume this is a feature request correct?
I will include the contents of the file below since I can upload it.
modules:
    os:
        version: GEIST-MIB-V3::productVersion.0
        serial: GEIST-MIB-V3::climateSerial.1
    sensors:
        state:
            data:
                    oid: GEIST-V4-MIB::internalTable
                    value: GEIST-V4-MIB::internalEntry
                    num_oid: '.1.3.6.1.4.1.21239.5.1.2.1.8.1'
                    descr: 'Dry Contact 1'
                    index: 1
                    state_name: dry-contact-1
                    group: Inputs
                    states:
                        - { value: 1, generic: 0, descr: open }
                        - { value: 0, generic: 0, descr: closed }
                    num_oid: '.1.3.6.1.4.1.21239.5.1.2.1.9.1'
                    descr: 'Dry Contact 2'
                    state_name: dry-contact-2
                    index: 2
                    group: Inputs
                    states:
                    num_oid: '.1.3.6.1.4.1.21239.5.1.2.1.10.1'
                    descr: 'Dry Contact 3'
                    state_name: dry-contact-3
                    index: 3
                    group: Inputs
                    states:
                    num_oid: '.1.3.6.1.4.1.21239.5.1.2.1.11.1'
                    descr: 'Dry Contact 4'
                    state_name: dry-contact-4
                    index: 4
                    group: Inputs
                    states:
                    num_oid: '.1.3.6.1.4.1.21239.5.1.2.1.12.1'
                    descr: 'Relay 1'
                    state_name: relay-1
                    index: 5
                    group: Outputs
                    states:
                        - { value: 0, generic: 0, descr: off }
                        - { value: 1, generic: 0, descr: on }
        temperature:
            options:
                divisor: 10
            data:
                    value: GEIST-V4-MIB::internalTemp
                    num_oid: '.1.3.6.1.4.1.21239.5.1.2.1.5.{{ $index }}'
                    descr: GEIST-V4-MIB::internalName
                    oid: GEIST-V4-MIB::tempSensorTable
                    value: GEIST-V4-MIB::tempSensorTemp
                    num_oid: '.1.3.6.1.4.1.21239.5.1.4.1.5.{{ $index }}'
                    descr: GEIST-V4-MIB::tempSensorName
                    oid: GEIST-V4-MIB::airFlowSensorTable
                    value: GEIST-V4-MIB::airFlowSensorTemp
                    num_oid: '.1.3.6.1.4.1.21239.5.1.5.1.5.{{ $index }}'
                    descr: GEIST-V4-MIB::airFlowSensorName
                    oid: GEIST-V4-MIB::dewPointSensorTable
                    value: GEIST-V4-MIB::dewPointSensorTemp
                    num_oid: '.1.3.6.1.4.1.21239.5.1.6.1.5.{{ $index }}'
                    descr: GEIST-V4-MIB::dewPointSensorName
                    oid: GEIST-V4-MIB::t3hdSensorTable
                    value: GEIST-V4-MIB::t3hdSensorIntTemp
                    num_oid: '.1.3.6.1.4.1.21239.5.1.8.1.6.{{ $index }}'
                    descr: GEIST-V4-MIB::t3hdSensorIntName
                    oid: GEIST-V4-MIB::thdSensorTable
                    value: GEIST-V4-MIB::thdSensorTemp
                    num_oid: '.1.3.6.1.4.1.21239.5.1.9.1.5.{{ $index }}'
                    descr: GEIST-V4-MIB::thdSensorName
                    value: GEIST-V4-MIB::thdSensorTempC
                    divisor: 1
                    num_oid: '.1.3.6.1.4.1.21239.2.32.1.5.{{ $index }}'
                    skip_values:
                            oid: GEIST-V4-MIB::thdSensorAvail
                            op: '!='
                            value: 1
                    oid: GEIST-MIB-V3::t3hdSensorTable
                    value: GEIST-MIB-V3::t3hdSensorIntTempC
                    divisor: 1
                    num_oid: '.1.3.6.1.4.1.21239.2.31.1.6.{{ $index }}'
                    descr: GEIST-MIB-V3::t3hdSensorName
                    skip_values:
                            oid: GEIST-MIB-V3::t3hdSensorAvail
                            op: '!='
                            value: 1
                    oid: GEIST-MIB-V3::climateRelayTable
                    value: GEIST-MIB-V3::climateRelayTempC
                    divisor: 1
                    num_oid: '.1.3.6.1.4.1.21239.2.26.1.5.{{ $index }}'
                    descr: GEIST-MIB-V3::climateRelayName
                    skip_values:
                            oid: GEIST-MIB-V3::climateRelayAvail
                            op: '!='
                            value: 1
                    oid: GEIST-MIB-V3::dewPointSensorTable
                    value: GEIST-MIB-V3::dewPointSensorTempC
                    divisor: 1
                    num_oid: '.1.3.6.1.4.1.21239.2.17.1.5.{{ $index }}'
                    descr: GEIST-MIB-V3::dewPointSensorName
                    skip_values:
                            oid: GEIST-MIB-V3::dewPointSensorAvail
                            op: '!='
                            value: 1
                    oid: GEIST-MIB-V3::vsfcTable
                    value: GEIST-MIB-V3::vsfcIntTempC
                    divisor: 1
                    num_oid: '.1.3.6.1.4.1.21239.2.13.1.8.{{ $index }}'
                    descr: GEIST-MIB-V3::vsfcName
                    skip_values:
                            oid: GEIST-MIB-V3::vsfcAvail
                            op: '!='
                            value: 1
                    oid: GEIST-MIB-V3::airFlowSensorTable
                    value: GEIST-MIB-V3::airFlowSensorTempC
                    divisor: 1
                    num_oid: '.1.3.6.1.4.1.21239.2.5.1.5.{{ $index }}'
                    descr: GEIST-MIB-V3::airFlowSensorName
                    skip_values:
                            oid: GEIST-MIB-V3::airFlowSensorAvail
                            op: '!='
                            value: 1
                    oid: GEIST-MIB-V3::tempSensorTable
                    value: GEIST-MIB-V3::tempSensorTempC
                    divisor: 1
                    num_oid: '.1.3.6.1.4.1.21239.2.4.1.5.{{ $index }}'
                    descr: GEIST-MIB-V3::tempSensorName
                    skip_values:
                            oid: GEIST-MIB-V3::tempSensorAvail
                            op: '!='
                            value: 1
                    oid: GEIST-MIB-V3::climateTable
                    value: GEIST-MIB-V3::climateTempC
                    divisor: 1
                    num_oid: '.1.3.6.1.4.1.21239.2.2.1.5.{{ $index }}'
                    descr: GEIST-MIB-V3::climateName
                    skip_values:
                            oid: GEIST-MIB-V3::climateAvail
                            op: '!='
                            value: 1
                    oid: GEIST-MIB-V3::dstsTable
                    value: GEIST-MIB-V3::dstsSourceATempC
                    divisor: 1
                    num_oid: '.1.3.6.1.4.1.21239.2.19.1.13.{{ $index }}'
                    descr: GEIST-MIB-V3::dstsName
                    skip_values:
                            oid: GEIST-MIB-V3::dstsAvail
                            op: '!='
                            value: 1
                    value: GEIST-MIB-V3::dstsSourceBTempC
                    divisor: 1
                    num_oid: '.1.3.6.1.4.1.21239.2.19.1.14.{{ $index }}'
                    skip_values:
                            op: '!='
                            value: 1
        current:
            data:
                    oid: GEIST-V4-MIB::rpmSensorTable
                    value: GEIST-V4-MIB::rpmSensorCurrent
                    num_oid: '.1.3.6.1.4.1.21239.5.1.10.1.10.{{ $index }}'
                    descr: GEIST-V4-MIB::rpmSensorName
                    divisor: 10
        voltage:
            data:
                    value: GEIST-V4-MIB::rpmSensorVoltage
                    num_oid: '.1.3.6.1.4.1.21239.5.1.10.1.6.{{ $index }}'
                    oid: GEIST-MIB-V3::pos60VdcSensorTable
                    value: GEIST-MIB-V3::pos60VdcSensorVoltage
                    num_oid: '.1.3.6.1.4.1.21239.2.33.1.5.{{ $index }}'
                    descr: GEIST-MIB-V3::pos60VdcSensorName
                    skip_values:
                            oid: GEIST-MIB-V3::pos60VdcSensorAvail
                            op: '!='
                            value: 1
                    oid: GEIST-MIB-V3::ctrl3ChIECTable
                    value: GEIST-MIB-V3::ctrl3ChIECVoltsA
                    num_oid: '.1.3.6.1.4.1.21239.2.25.1.6.{{ $index }}'
                    descr: GEIST-MIB-V3::ctrl3ChIECName
                    skip_values:
                            oid: GEIST-MIB-V3::ctrl3ChIECAvail
                            op: '!='
                            value: 1
                    value: GEIST-MIB-V3::ctrl3ChIECVoltsB
                    num_oid: '.1.3.6.1.4.1.21239.2.25.1.14.{{ $index }}'
                    skip_values:
                            op: '!='
                            value: 1
                    value: GEIST-MIB-V3::ctrl3ChIECVoltsC
                    num_oid: '.1.3.6.1.4.1.21239.2.25.1.22.{{ $index }}'
                    skip_values:
                            op: '!='
                            value: 1
                    oid: GEIST-MIB-V3::pos30VdcSensorTable
                    value: GEIST-MIB-V3::pos30VdcSensorVoltage
                    num_oid: '.1.3.6.1.4.1.21239.2.23.1.5.{{ $index }}'
                    descr: GEIST-MIB-V3::pos30VdcSensorName
                    skip_values:
                            oid: GEIST-MIB-V3::pos30VdcSensorAvail
                            op: '!='
                            value: 1
                    oid: GEIST-MIB-V3::neg48VdcSensorTable
                    value: GEIST-MIB-V3::neg48VdcSensorVoltage
                    num_oid: '.1.3.6.1.4.1.21239.2.22.1.5.{{ $index }}'
                    descr: GEIST-MIB-V3::neg48VdcSensorName
                    skip_values:
                            oid: GEIST-MIB-V3::neg48VdcSensorAvail
                            op: '!='
                            value: 1
                    value: GEIST-MIB-V3::dstsVoltsA
                    num_oid: '.1.3.6.1.4.1.21239.2.19.1.5.{{ $index }}'
                    skip_values:
                            op: '!='
                            value: 1
                    value: GEIST-MIB-V3::dstsVoltsB
                    num_oid: '.1.3.6.1.4.1.21239.2.19.1.7.{{ $index }}'
                    skip_values:
                            op: '!='
                            value: 1
                    oid: GEIST-MIB-V3::ctrl3ChTable
                    value: GEIST-MIB-V3::ctrl3ChVoltsA
                    num_oid: '.1.3.6.1.4.1.21239.2.14.1.5.{{ $index }}'
                    descr: GEIST-MIB-V3::ctrl3ChName
                    skip_values:
                            oid: GEIST-MIB-V3::ctrl3ChAvail
                            op: '!='
                            value: 1
                    value: GEIST-MIB-V3::ctrl3ChVoltsB
                    num_oid: '.1.3.6.1.4.1.21239.2.14.1.12.{{ $index }}'
                    skip_values:
                            op: '!='
                            value: 1
                    value: GEIST-MIB-V3::ctrl3ChVoltsC
                    num_oid: '.1.3.6.1.4.1.21239.2.14.1.19.{{ $index }}'
                    skip_values:
                            op: '!='
                            value: 1
                    oid: GEIST-MIB-V3::pow3ChTable
                    value: GEIST-MIB-V3::pow3ChVoltsA
                    num_oid: '.1.3.6.1.4.1.21239.2.11.1.6.{{ $index }}'
                    descr: GEIST-MIB-V3::pow3ChName
                    skip_values:
                            oid: GEIST-MIB-V3::pow3ChAvail
                            op: '!='
                            value: 1
                    value: GEIST-MIB-V3::pow3ChVoltsB
                    num_oid: '.1.3.6.1.4.1.21239.2.11.1.15.{{ $index }}'
                    skip_values:
                            op: '!='
                            value: 1
                    value: GEIST-MIB-V3::pow3ChVoltsC
                    num_oid: '.1.3.6.1.4.1.21239.2.11.1.24.{{ $index }}'
                    skip_values:
                            op: '!='
                            value: 1
                    oid: GEIST-MIB-V3::powMonTable
                    value: GEIST-MIB-V3::powMonVolts
                    num_oid: '.1.3.6.1.4.1.21239.2.3.1.6.{{ $index }}'
                    descr: GEIST-MIB-V3::powMonName
                    skip_values:
                            oid: GEIST-MIB-V3::powMonAvail
                            op: '!='
                            value: 1
                    value: GEIST-MIB-V3::climateVolts
                    divisor: 1
                    num_oid: '.1.3.6.1.4.1.21239.2.2.1.14.{{ $index }}'
                    skip_values:
                            op: '!='
                            value: 1
        humidity:
            data:
                    value: GEIST-V4-MIB::thdSensorHumidity
                    num_oid: '.1.3.6.1.4.1.21239.5.1.9.1.6.{{ $index }}'
                    value: GEIST-V4-MIB::t3hdSensorIntHumidity
                    num_oid: '.1.3.6.1.4.1.21239.5.1.8.1.7.{{ $index }}'
                    value: GEIST-V4-MIB::internalHumidity
                    num_oid: '.1.3.6.1.4.1.21239.5.1.2.1.6.{{ $index }}'
                    oid: GEIST-MIB-V3::thdSensorTable
                    value: GEIST-MIB-V3::thdSensorHumidity
                    num_oid: '.1.3.6.1.4.1.21239.2.32.1.7.{{ $index }}'
                    descr: GEIST-MIB-V3::thdSensorName
                    skip_values:
                            oid: GEIST-MIB-V3::thdSensorAvail
                            op: '!='
                            value: 1
                    value: GEIST-MIB-V3::t3hdSensorIntHumidity
                    divisor: 1
                    num_oid: '.1.3.6.1.4.1.21239.2.31.1.8.{{ $index }}'
                    skip_values:
                            op: '!='
                            value: 1
                    value: GEIST-MIB-V3::dewPointSensorHumidity
                    divisor: 1
                    num_oid: '.1.3.6.1.4.1.21239.2.17.1.7.{{ $index }}'
                    skip_values:
                            op: '!='
                            value: 1
                    value: GEIST-MIB-V3::airFlowSensorHumidity
                    divisor: 1
                    num_oid: '.1.3.6.1.4.1.21239.2.5.1.8.{{ $index }}'
                    skip_values:
                            op: '!='
                            value: 1
                    value: GEIST-MIB-V3::climateHumidity
                    divisor: 1
                    num_oid: '.1.3.6.1.4.1.21239.2.2.1.7.{{ $index }}'
                    skip_values:
                            op: '!='
                            value: 1
        airflow:
            data:
                    value: GEIST-V4-MIB::airFlowSensorFlow
                    num_oid: '.1.3.6.1.4.1.21239.5.1.5.1.6.{{ $index }}'
                    value: GEIST-MIB-V3::climateAirflow
                    divisor: 1
                    num_oid: '.1.3.6.1.4.1.21239.2.2.1.9.{{ $index }}'
                    skip_values:
                            op: '!='
                            value: 1
        fanspeed:
            data:
                    value: GEIST-MIB-V3::vsfcFanSpeed
                    divisor: 1
                    num_oid: '.1.3.6.1.4.1.21239.2.13.1.7.{{ $index }}'
                    skip_values:
                            op: '!='
                            value: 1
