I am trying to add an IMS4000 to my instance. This device has an available MIB, and I have managed to discover it correctly after adding an appropriate yaml file. However, it has some oddly-laid-out sensors I have been unable to add. The sensors are in two nested, parallel structures, as follows (from snmpwalk
Values are in 1.3.6.1.4.1.8338.1.1.1.(1…17).8.1.1.7.(1…11)
Sensor types/units are in 1.3.6.1.4.1.8338.1.1.1.(1…17).8.1.1.3.(1…11)
Human names for sensors are in 1.3.6.1.4.1.8338.1.1.1.(1…17).8.1.1.2.(1…11)
I did find an existing PHP file, precache/avtech.inc.php, which uses regexes to solve a similar problem, but I’m not sure exactly how to use the precache mechanism to pick up these sensors – if anyone could point me to documentation for the meaning of the precache variables and how they’re interpreted into sensor entries, I’d appreciate it.
- The output of
./validate.php
LibreNMS | 23.1.0-19-gaa033ec3c (2023-02-02T13:07:59+00:00)
DB Schema | 2022_08_15_084507_add_rrd_type_to_wireless_sensors_table (248)
PHP | 8.2.2
Python | 3.9.2
Database | MariaDB 10.5.18-MariaDB-0+deb11u1
RRDTool | 1.7.2
SNMP | 5.9
[OK] Composer Version: 2.5.1
[FAIL] Time between this server and the mysql database is off
Mysql time 2023-02-06 16:03:31
PHP time 2023-02-06 21:03:31
[FAIL] You have a different system timezone (EST) than the php configured timezone (UTC)
Please correct either your system timezone or your timezone set in /etc/php/8.2/cli/php.ini.
[WARN] Global lnms shortcut not installed. lnms command must be run with full path
sudo ln -s /opt/librenms/lnms /usr/local/bin/lnms
[WARN] Bash completion not installed. lnms command tab completion unavailable.
sudo cp /opt/librenms/misc/lnms-completion.bash /etc/bash_completion.d/
[WARN] Log rotation not enabled, could cause disk space issues
sudo cp /opt/librenms/misc/librenms.logrotate /etc/logrotate.d/librenms
Modified Files:
includes/definitions/ird.yaml
