I configured librenms with local domain name as nms.gits.lan
Added few devices and created default dashboard for rest of the users
However, as Let’s Encrypt require public domain I created it as nms[.]greenko[.]net.
updated config file with base_url to secure:// nms[.]greenko[.]net
After configuration when I try to open with secure://nms[.]greenko[.]net
Unable to see any devices which are configured earlier.
If I change to secure://nms[.]gits[.]lan
Able to see all the devices without any issue
Add [.] as I’m unable to post more than two urls. secure=https - The output of
./validate.php
Validate output is the same both the url configuration.
LibreNMS | 1.33-279-ga391e62
DB Schema | 226
PHP | 7.1.11
MySQL | 5.5.56-MariaDB
RRDTool | 1.4.8
SNMP | NET-SNMP 5.7.2
[WARN] Your install is over 24 hours out of date, last update: Wed, 27 Dec 2017 05:36:09 +0000
If it’s an issue with the WebUI then please consider including the browser version you are using.
