Not sure this is the fix. Perhaps just deleting existing sessions would have done the same.
Hi Murrant,
Yes i did delete the existing session but the problem was there. But after commenting that line everything working fine as expected.
Thank you
That is really odd, I wonder what the problem is.
@murrant And also as i ran discovery.php i can still see MySQL server has gone away. Any action has to be taken from our end.
Sounds like you are having issues with your MySQL server.
So any way is there i can fix it without disturbing our environment?
Yes, you need to fix whatever issue you are having. Start checking your msyql server logs. Run mysqltuner. Check system logs.
here is the result of mysql tuner
General recommendations:
Run OPTIMIZE TABLE to defragment tables for better performance
Set up a Password for user with the following SQL statement ( SET PASSWORD FOR ‘user’@‘SpecificDNSorIp’ = PASSWORD(‘secure_password’); )
Reduce your overall MySQL memory footprint for system stability
Adjust your join queries to always utilize indexes
When making adjustments, make tmp_table_size/max_heap_table_size equal
Reduce your SELECT DISTINCT queries which have no LIMIT clause
Increase table_open_cache gradually to avoid file descriptor limits
Read this before increasing table_open_cache over 64: http://bit.ly/1mi7c4C
Beware that open_files_limit (50005) variable
should be greater than table_open_cache ( 400)
Variables to adjust:
*** MySQL’s maximum memory usage is dangerously high ***
*** Add RAM before increasing MySQL buffer variables ***
query_cache_limit (> 1M, or use smaller result sets)
query_cache_size (> 16M)
join_buffer_size (> 128.0K, or always use indexes with joins)
tmp_table_size (> 16M)
max_heap_table_size (> 16M)
table_open_cache (> 400)
innodb_buffer_pool_size (>= 2G) if possible.
innodb_buffer_pool_instances (=1)
innodb_log_buffer_size (>= 8M)
Kindly let me know how to resolve this
It tells you what the recommendations are and what you need to do.
@tleadley, what config file specifically has the cookie parameter?
config.php
HI tleadley ,
i got the same problem
config.php ?
We having same issue https://prnt.sc/kwq45a
$config[‘secure_cookies’] = true; line is not available in config.php .what to do?
./validate.php
| LibreNMS | 1.43-107-g4f6e2b4 |
| DB Schema | 268 |
| PHP | 7.2.9 |
| MySQL | 5.5.60-MariaDB |
| RRDTool | 1.4.8 |
| SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.7.2
[FAIL] Missing PHP extension: mysqlnd
[FIX] Please install mysqlnd
i am getting this any idea?
tail -f /opt/librenms/log/librenms.log is
/opt/librenms/poller.php 50 2018-09-20 17:51:03 - 1 devices polled
Please see my reply on Problem with backend error
ok .thanks
I would add the line to the config.php file and instead set it to false.
I doubt this will be your issue without knowing more about your setup so this would be something to try. I did notice some failed Plugin entries, maybe start there!
In my case I have pfsense running haproxy, so a reverse proxy conntributed to my problem. I am using Apache on Ubuntu 16.04. So if you are running a reverse proxy I would look at your proxy configuration in addition to your librenms setup!
More information about your build could go a long way to help isolate the issue. I mean the distro you are using and if you chose Apache or Nginx, using SSL etc
