Greetings!
First of all - I want to thank all the team for the great product. You make my work easier
But still i’m new to librenms and have some problems making correct rules.
I want to create a group for devices, which contain “wdx” or “mix” in the hostname, or ip-address, ending with .1 or .2 or greater than .112.
So I’ve created a roolset:
https://prnt.sc/jsuubg
But group is empty, what’s wrong with my ruleset? Groups based just on “wdx” or “mix” hostnames work just fine. -
What whould be the preferable to make rules based on device groups?
Should I use device_group_device.device_group_id entity or something else? What’s group_id - is it a groupname? -
I’m using “Interface Errors Rate greater than 100” rule, but i don’t want to get such a warnings from my wifi-APs, so some statments where added:
https://prnt.sc/jsuvkv
But still I recive alerts from “ath” ports. What’s the possible problem whith the rules? -
Is that possible to get reed of the “Rule created, no faults found” messages in the alert log?
Not a big problem, realy, but spams message log a bit, when adding a couple of new devices.
