I tested various possible combinations
Still can’t get PORT NOTES information Notes* %ports.ifDescr ** Notes* %port_descr_notes ** Notes* %port_id_notes ** Notes* %port.notes ** Notes* %notes **
I have seen that article
It should be more than just like I can show the amount of hard disk usage on email via “%value.storage_used”
I hope someone can provide possible ideas. Otherwise, the notification will not be sent out to know the main function and importance of this PORT.
hi laf
I’m using Meta.
Description Except for https://docs.librenms.org/#Alerting/Templates/#examples
There are still parameters that can be used.
What I need is a separate annotation for each port. It is convenient to know the purpose of the port when receiving the email in the first time.
Thank you for your help
