hi, i have problems with transport.
Yesterday i stopped getting any alert in my telegream bot. Test transport worked correctly, in alert hystory, too everything correctly, but no one notification came. I reset everything rules to default but nothing changes. At night I started to receive notifications, some on time, but some on about 6 hours ago alert
Now i get multiple notification at once, with 15 minutes delay, some notification about one alert repeat and repeat again. Аnd also for example I get ping latency notifications but I don’t get “device up/down” although the rule and transport settings are the same
my validate:====================================
Component | Version |
LibreNMS | 21.4.0-18-g07900cc |
DB Schema | 2021_04_08_151101_add_foreign_keys_to_port_group_port_table (208) |
PHP | 7.3.27 |
Python | 3.6.8 |
MySQL | 10.2.37-MariaDB |
RRDTool | 1.4.8 |
SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 2.0.12
[WARN] Log rotation not enabled, could cause disk space issues
sudo cp /opt/librenms/misc/librenms.logrotate /etc/logrotate.d/librenms
I do not understand at all what is happening. What other tests i can do for find a problem?
and once again note - from device to lnms everything correct and is on time, from lnms to telegram test transport come at time the click,
something wrong between this steps
