Hi I am having issues setting up alert transports. It keeps saying failed. Do you know why?
Have you setup your email options for alerting in global settings?
yes
is anything wrong here?
only thing that looks odd to me is “from email adress”. That should read email adress only e.g [email protected]
Yea still getting the error when i make the from email address my own.
Well, if email address used to send email is correct and allowed to send via office365 and your credentials entered are for that email address, it should work. Otherwise i dont know.
Also i believe email used for sending must have real domain name e.g domain.com and not .local
Looking for help with alert configuration. willing to pay for help.
Version [1.60-58-g8a2ce01 - Mon Feb 24 2020 03:49:42 GMT-0500]
Still having trouble it will setting up transports gives me an error every time.
what is the issue? Maybe post some screenshots?
edit deleting pic
Whats settings do you have for mail?
Global Settings -> Alerting -> Email Options.
edit deleting pic
Try “Mail” for how to deliver
Same error
Weird - Need to confirm all your settings are right, also you can check the logs.
at /opt/librenms/logs/librenms.log
can i see the logs in the webgui?
no, you can not.
can you do a share screen to help me?
