Hi, this happened some days ago. It looks like after some update the Alertlog entries widget is missing OK statuses and shows only Alert statuses. Please see the screenshot:
Output of validate.php:
Component | Version |
LibreNMS | 1.43-61-gc222d0e |
DB Schema | 267 |
PHP | 5.6.37 |
MySQL | 5.5.60 |
RRDTool | 1.3.8 |
SNMP | NET-SNMP 5.5 |
[OK] Composer Version: 1.7.2
[WARN] IPv6 is disabled on your server, you will not be able to add IPv6 devices.`
It happened on two independent installations - one which I’m using in work and also in the which is my personal. Could you please help?
