I am running a default alert rule “Device Down! Due to no ICMP response.”
Most of my devices have “child” or parent configured. (this was done via api to all of the ~1500 devices)
the issue is I receive notification about both the parent and the child device once the parent device goes down…
I am missing something or is there anything I should look into?
Hello All, is there to know issue with the toppic?
Could it be me doing something wrong?
Attaching the output of ./validate.php
-bash-4.2$ ./validate.php
Component
Version
LibreNMS
21.7.0-69-g9723c44
DB Schema
2021_08_04_102914_add_syslog_indexes (213)
PHP
7.3.28
Python
3.6.8
MySQL
10.5.10-MariaDB
RRDTool
1.4.8
SNMP
NET-SNMP 5.7.2
[OK] Composer Version: 2.1.5
Modified Files:
LibreNMS/Alert/RunAlerts.php
In the description of the feature it says: “The aim for that is, if all parent devices are down, alert contacts will not receive redundant alerts for dependent devices.” It is unclear if this means that the alerts for the children will not go through to Transport (if any is defined) of it the alerts should not be raised. From your description, it seems that the first alternative is the correct one.
I have a similar observation - during a complete site outage: as the devices return polling information at different times - the alerts appear to check the parent status at that point, and if not down through luck of timing, it will notify after the configured delay without checking the parent status again. This means the majority of devices on the site will notify, and this includes the recovery alerts.
Have not looked at the code yet, but to be true to its aim, it should be checking the parent status at each decision point from alert through to final notification.
