I am using Cloudflare for the FQDN of some devices and have those added in the hosts file with it’s real IP address (to not expose the origin IP in DNS)
It would help to have some way to disable/enable this check globally (or even per device?) so the event logs don’t get flooded with “Device IP changed” alerts (since Cloudflare changes the IPs you are given based on geolocation.)
Example: device01.contoso.com has a local IP of 192.168.1.105 but resolves externally to Cloudflare, so in my hosts file I added device01.contoso.com to point to IP 192.168.1.105.
