I receive this error when I try to update a Cisco router
W, [2021-11-19T15:01:54.345018 #15321] WARN -- : 192.168.62.11 raised Timeout::Error with msg "execution expired"
W, [2021-11-19T15:01:55.044232 #15321] WARN -- : /192.168.62.11 status no_connection, retry attempt 1
W, [2021-11-19T15:02:18.355145 #15321] WARN -- : 192.168.62.11 raised Timeout::Error with msg "execution expired"
W, [2021-11-19T15:02:19.048856 #15321] WARN -- : /192.168.62.11 status no_connection, retry attempt 2
W, [2021-11-19T15:02:42.355197 #15321] WARN -- : 192.168.62.11 raised Timeout::Error with msg "execution expired"
W, [2021-11-19T15:02:43.052984 #15321] WARN -- : /192.168.62.11 status no_connection, retry attempt 3
W, [2021-11-19T15:03:06.555660 #15321] WARN -- : 192.168.62.11 raised Timeout::Error with msg "execution expired"
W, [2021-11-19T15:03:07.057108 #15321] WARN -- : /192.168.62.11 status no_connection, retries exhausted, giving up
I need to know what is the problem ? and How I can check what is happening ? I mean which command should to use ?
The Config file
username: test
password: test
model: junos
resolve_dns: true
interval: 3600
log: ~/.config/oxidized/log
use_syslog: false
debug: false
threads: 30
timeout: 20
retries: 3
vars:
enable: test
groups: {}
rest: 192.168.55.111:8888
input:
default: ssh, telnet
debug: false
ssh:
secure: false
output:
default: git
git:
user: Oxidized
email: [email protected]
repo: "~/.config/oxidized/oxidized.git"
source:
default: http
debug: false
http:
url: http://192.168.55.112/api/v0/oxidized
scheme: http
file: "/home/oxidized/.config/oxidized/router.db"
delimiter: !ruby/regexp /:/
map:
model: os
username: username
password: password
var_map:
enable: 4
headers:
X-Auth-Token: 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXX'
model_map:
Vyatta: Vyatta
cisco: ios
mikrotik: routeros
Best Regards
