Another Oxidized + librenms setup issue
We currently run rancid and librenms separately. Using the post here https://www.reddit.com/r/LibreNMS/comments/7hb21o/librenms_oxidized/ I was able to setup oxidized and have it running with no issues. I can curl to the oxidized server with the hostname of some of our network hardware. However, no matter how many guides I have followed, when I click on the config tab I get: we couldn’t retrieve the device information from Oxidized. Turning on debug for librenms doesn’t show any sql or php errors. I can’t seem to enable enough debug option in oxidized to show incoming API requests. Here is my config for oxidized:
username: oxidized
password: -----------
model: junos
interval: 300
use_syslog: false
debug: true
threads: 30
timeout: 20
retries: 3
prompt: !ruby/regexp /([\[email protected]]+[#>]\s?)$/
rest: 10.241.100.16:8080
next_adds_job: false
vars: {}
groups: {}
models: {}
pid: "/root/.config/oxidized/pid"
log: "/root/.config/oxidized/log"
input:
default: ssh, telnet
debug: true
ssh:
secure: false
output:
default: git
git:
user: git
email: [email protected]
repo: "/root/.config/oxidized/devices.git"
source:
default: http
http:
url: http://10.241.100.16/api/v0/oxidized
map:
model: os
group: group
headers:
X-Auth-Token: '-------------------------'
model_map:
cisco: ios
juniper: junos
hooks:
post-commit:
type: exec
events: [node_success, post_store]
cmd: 'cd /root/.config/oxidized/devices.git && git push -f -q /root/.config/oxidized/devices.git master'
The data that oxidized stores is as follows:
{:name=>"10.229.254.16", :full_name=>"10.229.254.16", :ip=>"10.229.254.16", :group=>nil, :model=>"JunOS", :last=> {:start=>2018-05-22 00:19:26 UTC, :end=>2018-05-22 00:19:39 UTC, :status=>:success, :time=>13.361407251}, :vars=>nil}
All oxidized options are enabled on the librenms side of things and I am using http://10.241.100.16:8080 fpr the API field. Its funny that oxidized can pull in all the information from librenms but librenms can’t pull the config. I have been working on this all day today and I can’t figure it out. Please, help!
Do you see the config diffs in oxidized?
Try and curl http://10.241.100.16:8080/node/show/$hostname?format=json
Post your LibreNMS oxidized config.
I finally rebooted and went home.This morning I logged in and now everything working. Oh well, thanks for the help.
Having the same issue at the moment
oxidized 0.24.0
Here is json:
{“name”:“name-here”,“full_name”:“name-here”,“ip”:“192.168.191.1”,“group”:null,“model”:“PanOS”,“last”:{“start”:“2018-07-03 14:00:37 UTC”,“end”:“2018-07-03 14:00:46 UTC”,“status”:“success”,“time”:9.017765973},“vars”:null,“mtime”:“unknown”}
I’m using default group for all and only model.
No librenms integration, just router.db.
oxidized itself works perfect, shows config etc, but not from libre.
running oxidized as service, don’t know if that matters.
P.S. reboot didn’t help :slight_smile:
