Hello
I am trying to get images with the get_graph_by_port_hostname function of the librenms API.
Without any input parameters it is working.
curl -H 'X-Auth-Token: THISISMYAUTHTOKEN' 'http://192.168.0.34/api/v0/devices/localhost/ports/ens3/port_bits' > image.png
returns the right graph.
But as soon as I try to give any input parameters, e.g.
curl -X POST -d '{"to":"1500288900","from":"1500202500"}' -H 'X-Auth-Token: HISISMYAUTHTOKEN''http://192.168.0.34/api/v0/devices/localhost/ports/ens3/port_bits'`
it returns a 404 not found page.
My installation is the default Ubuntu-image, which I updated today during my testing.
This is the output of validate.php:
LibreNMS | 20ce209b2710f424f9be4f128a6eeab43074b626
DB Schema | 199
PHP | 7.0.18-0ubuntu0.16.04.1
MySQL | 10.0.29-MariaDB-0ubuntu0.16.04.1
RRDTool | 1.5.5
SNMP | NET-SNMP 5.7.3
[FAIL] You have a different system timezone (BST) specified to the php configured timezone (UTC), please correct this.
Other Calls with Parameters seam to work:
curl -X POST -d '{"hostname":"localhost","version":"v1","community":"public"}' -H 'X-Auth-Token: HISISMYAUTHTOKEN' 'http://192.168.0.34/api/v0/devices'
"status": "error",
"message": "Already have host localhost"
If you need any further debugging information please let me know.
Greetings Jo
