API Transport used for sending SMS through SMS Gateway, ignores variables like $msg in options and sends just “$msg” text instead. Do you have an idea what Im doing wrong?
I am using GET method and in Optin field those parameters as required by gateway.
Cmd=SMS
Nmr=XXXXXXXXXXXX
Text={{$msg}}
If I put the fixed characters to the parameter Text everything works well.
