i’m trying to add apache and os updates on my plesk server on centos 7.
On that host i’ve selinux with enforcing mode.
i’m using snmp instead agent on that host and i’ve downloaded and enabled script for snmpd respectively for apache stats and os update.
For apache everything works on localhost and if i do curl http://172.16.110.4/server-status?auto
but on host if i see audit.log denied i’ve that output:
m_r:snmpd_t:s0 tcontext=system_u:object_r:http_port_t:s0 tclass=tcp_socket
type=AVC msg=audit(1529679006.356:37050): avc: denied { open } for pid=10149 comm="yum" path="/var/log/yum.log" dev="dm-0" ino=67455085 sco
ntext=system_u:system_r:snmpd_t:s0 tcontext=unconfined_u:object_r:rpm_log_t:s0 tclass=file
type=AVC msg=audit(1529679006.540:37051): avc: denied { write } for pid=10149 comm="yum" name="7" dev="dm-0" ino=134310996 scontext=system_
u:system_r:snmpd_t:s0 tcontext=unconfined_u:object_r:rpm_var_cache_t:s0 tclass=dir
type=AVC msg=audit(1529679006.541:37052): avc: denied { write } for pid=10149 comm="yum" name="PLESK_17_8_11-extras" dev="dm-0" ino=9821 sc
ontext=system_u:system_r:snmpd_t:s0 tcontext=unconfined_u:object_r:rpm_var_cache_t:s0 tclass=dir
so i think that selinux blocked call from my librenms server.
how can i allow that?
My output of validate.php
Component | Version |
LibreNMS | 1.40-29-g5af520a |
DB Schema | 252 |
PHP | 7.2.6 |
MySQL | 5.5.56-MariaDB |
RRDTool | 1.4.8 |
SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.6.5
