php discovery.php -d -h fqdn -m os
LibreNMS Discovery
SQL[select migration
from migrations
order by id
desc limit 1 [] 0.81ms]
SQL[select count(*) as aggregate from migrations
limit 1 [] 0.72ms]
SQL[SELECT version() [] 0.57ms]
Version info:
Commit SHA:
Commit Date: 1569841625
DB Schema: 2019_09_05_153524_create_notifications_attribs_index (141)
PHP: 7.2.26
MySQL: 5.7.27-log
RRDTool: 1.7.2
SNMP: NET-SNMP 5.7.3
Updating os_def.cache…
Done
Override discovery modules: os
SQL[SELECT * FROM devices
WHERE disabled = 0 AND snmp_disable = 0 AND hostname
LIKE ‘fqdn’ ORDER BY device_id DESC [] 1.62ms]
SQL[SELECT * FROM devices_attribs WHERE device_id
= ? [25] 0.77ms]
fqdn 25 grandstream-ht [FPING] /usr/local/sbin/fping -e -q -c 3 -p 500 -t 500 fqdn
array (
‘xmt’ => ‘3’,
‘rcv’ => ‘3’,
‘loss’ => ‘0’,
‘min’ => ‘0.28’,
‘max’ => ‘0.97’,
‘avg’ => ‘0.53’,
‘exitcode’ => 0,
SQL[INSERT IGNORE INTO device_perf
(xmt
,rcv
,loss
,min
,max
,avg
,device_id
,timestamp
,debug
) VALUES (:xmt,:rcv,:loss,:min,:max,:avg,:device_id,NOW(),:debug) {“xmt”:“3”,“rcv”:“3”,“loss”:“0”,“min”:“0.28”,“max”:“0.97”,“avg”:“0.53”,“device_id”:25,“debug”:"[]"} 5.21ms]
SNMP Check response code: 0
SQL[SELECT attrib_value FROM devices_attribs WHERE device_id
= ? AND attrib_type
= ? [25,“poll_mib”] 1.29ms]
Attempting to initialize OS: grandstream-ht
OS initialized as Generic
Modules status: Global+
OS
Device
Load disco module core
SNMP[’/usr/local/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OUQn’ ‘-m’ ‘SNMPv2-MIB’ ‘-M’ ‘/usr/local/www/librenms/mibs:/usr/local/www/librenms/mibs/grandstream’ ‘-t’ ‘1’ ‘-r’ ‘15’ ‘udp:HOSTNAME:161’ ‘sysName.0’ ‘sysObjectID.0’ ‘sysDescr.0’]
...0 = fqdn
...0 = ..4.1.8
...0 = Linux fqdn 4.19.99-1-lts #1 SMP Mon, 27 Jan 2020 21:30:28 +0000 x86_64
Runtime for discovery module ‘core’: 0.0130 seconds with 1104 bytes
SNMP: [2/0.04s] MySQL: [4/0.01s] RRD: [0/0.00s]
Unload disco module core
OS+
Device
Load disco module os
SNMP[’/usr/local/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Ovq’ ‘-M’ ‘/usr/local/www/librenms/mibs:/usr/local/www/librenms/mibs/grandstream’ ‘-t’ ‘1’ ‘-r’ ‘15’ ‘udp:HOSTNAME:161’ ‘SNMPv2-MIB::sysDescr.0’]
SNMP[’/usr/local/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Ovqn’ ‘-M’ ‘/usr/local/www/librenms/mibs:/usr/local/www/librenms/mibs/grandstream’ ‘-t’ ‘1’ ‘-r’ ‘15’ ‘udp:HOSTNAME:161’ ‘SNMPv2-MIB::sysObjectID.0’]
..4.1.8
| Linux fqdn 4.19.99-1-lts #1 SMP Mon, 27 Jan 2020 21:30:28 +0000 x86_64 | .1.3.6.1.4.1.8072.3.2.10 |
SNMP[’/usr/local/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/usr/local/www/librenms/mibs:/usr/local/www/librenms/mibs/grandstream’ ‘-t’ ‘1’ ‘-r’ ‘15’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.1166.1.621.14.2.0’]
No Such Object available on this agent at this OID
SNMP[’/usr/local/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/usr/local/www/librenms/mibs:/usr/local/www/librenms/mibs/grandstream’ ‘-t’ ‘1’ ‘-r’ ‘15’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.2021.7890.1.101.1’]
SNMP[’/usr/local/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/usr/local/www/librenms/mibs:/usr/local/www/librenms/mibs/grandstream’ ‘-t’ ‘1’ ‘-r’ ‘15’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.9193.1.0’]
SNMP[’/usr/local/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/usr/local/www/librenms/mibs:/usr/local/www/librenms/mibs/grandstream’ ‘-t’ ‘1’ ‘-r’ ‘15’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.8072.1.3.2.3.1.1.6.100.105.115.116.114.111’]
No Such Instance currently exists at this OID
SNMP[’/usr/local/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/usr/local/www/librenms/mibs:/usr/local/www/librenms/mibs/grandstream’ ‘-t’ ‘1’ ‘-r’ ‘15’ ‘udp:HOSTNAME:161’ ‘SFA-INFO::systemName.0’]
SNMP[’/usr/local/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-m’ ‘SYNOLOGY-SYSTEM-MIB’ ‘-M’ ‘/usr/local/www/librenms/mibs:/usr/local/www/librenms/mibs/grandstream:/usr/local/www/librenms/mibs/synology’ ‘-t’ ‘1’ ‘-r’ ‘15’ ‘udp:HOSTNAME:161’ ‘systemStatus.0’]
SNMP[’/usr/local/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/usr/local/www/librenms/mibs:/usr/local/www/librenms/mibs/grandstream’ ‘-t’ ‘1’ ‘-r’ ‘15’ ‘udp:HOSTNAME:161’ ‘HOST-RESOURCES-MIB::hrSystemInitialLoadParameters.0’]
"BOOT_IMAGE=/boot/vmlinuz-linux-lts root=UUID=364e4c94-4ba8-4d64-9b46-7418e76ebc11 rw
SNMP[’/usr/local/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/usr/local/www/librenms/mibs:/usr/local/www/librenms/mibs/grandstream’ ‘-t’ ‘1’ ‘-r’ ‘15’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.12148.10.2.6.0’]
SNMP[’/usr/local/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-m’ ‘EXTRAHOP-MIB’ ‘-M’ ‘/usr/local/www/librenms/mibs:/usr/local/www/librenms/mibs/grandstream:/usr/local/www/librenms/mibs/extrahop’ ‘-t’ ‘1’ ‘-r’ ‘15’ ‘udp:HOSTNAME:161’ ‘extrahopInfoVersionString’]
SNMP[’/usr/local/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/usr/local/www/librenms/mibs:/usr/local/www/librenms/mibs/grandstream:/usr/local/www/librenms/mibs/checkpoint’ ‘-t’ ‘1’ ‘-r’ ‘15’ ‘udp:HOSTNAME:161’ ‘CHECKPOINT-MIB::osName.0’]
OS: Grandstream HT (grandstream-ht)
Runtime for discovery module ‘os’: 0.2980 seconds with 40024 bytes
SNMP: [12/0.29s] MySQL: [0/0.00s] RRD: [0/0.00s]
Unload disco module os
= ? AND attrib_type
= ? [25,“poll_mib”] 0.96ms]
SQL[UPDATE devices
set last_discovered
=NOW(),last_discovered_timetaken
=? WHERE device_id
= ? [1.3729999999999999982236431605997495353221893310546875,25] 1.64ms]
Discovered in 1.373 seconds
SQL[INSERT IGNORE INTO perf_times
(type
,doing
,start
,duration
,devices
,poller
) VALUES (:type,:doing,:start,:duration,:devices,:poller) {“type”:“discover”,“doing”:“fqdn”,“start”:1581230501.952816009521484375,“duration”:“1.605”,“devices”:1,“poller”:“fqdn”} 1.29ms]
discovery.php fqdn 2020-02-09 06:41:43 - 1 devices discovered in 1.605 secs
SNMP [14/0.33s]: Get[14/0.33s] Getnext[0/0.00s] Walk[0/0.00s]
MySQL [7/0.02s]: Cell[1/0.00s] Row[1/0.00s] Rows[2/0.00s] Column[0/0.00s] Update[1/0.00s] Insert[2/0.01s] Delete[0/0.00s]
RRD [0/0.00s]: Update[0/0.00s] Create [0/0.00s] Other[0/0.00s]
