Hi
Maybe I missed something or I am wrong about what does the “Auto Discovery”. LibreNMS has been installed 4 weeks ago. I have three VLANs (one “home”, one “IoT” network, one “IP cam” network). No device has been discovered automatically : all the 7 devices shown under the “Devices” menu have been added manually.
And it lacks 20 or 30 other IoT devices still undiscovered. I understand the Auto discovery function should populate automatically the “Devices” tab right ? Even if these component don’t have SNMP, they should be discovered through IP right (yes, they answer to ping requests) ? So I don’t understand what is going wrong…
Here is my config file:
root@admin:/opt/librenms# cat config.php|grep “^[^#;]”
<?php
$config[‘db_socket’] = ‘’;
// This is the user LibreNMS will run as
//Please ensure this user is created and has the correct permissions to your install
$config[‘user’] = ‘librenms’;
$config[‘snmp’][‘community’] = array(“public”, ‘my_servers’);
$config[‘nets’][] = ‘192.168.0.0/24’;
$config[‘nets’][] = ‘192.168.101.0/24’;
$config[‘nets’][] = ‘192.168.215.0/24’;
$config[‘discovery_by_ip’] = true;
$config[‘discovery_modules’][‘discovery-arp’] = true;
$config[‘auth_mechanism’] = “mysql”; # default, other options: ldap, http-auth
$config[‘mydomain’] = ‘mydom.int’;
$config[‘show_services’] = 1;
$config[‘nagios_plugins’] = “/usr/lib/nagios/plugins”;
Here is the validate.php output:
root@admin:/opt/librenms# ./validate.php
LibreNMS | 1.68-50-g6cd42b3ee
DB Schema | 2020_10_03_1000_add_primary_key_transport_group_transport (186)
PHP | 7.2.24-0ubuntu0.18.04.7
Python | 3.6.9
MySQL | 10.1.44-MariaDB-0ubuntu0.18.04.1
RRDTool | 1.7.0
SNMP | NET-SNMP 5.7.3
[OK] Composer Version: 1.10.15
[WARN] PHP version 7.3 is the minimum supported version as of November, 2020. We recommend you update PHP to a supported version (7.4 suggested) to continue to receive updates. If you do not update PHP, LibreNMS will continue to function but stop receiving bug fixes and updates.
And finally the crontab (untouched):
root@admin:/opt/librenms# cat /etc/cron.d/librenms
# Using this cron file requires an additional user on your system, please see install docs.
* * * * * librenms /opt/librenms/alerts.php >> /dev/null 2>&1
# Daily maintenance script. DO NOT DISABLE!
# If you want to modify updates:
# Switch to monthly stable release: https://docs.librenms.org/General/Releases/
# Disable updates: https://docs.librenms.org/General/Updating/
15 0 * * * librenms /opt/librenms/daily.sh >> /dev/null 2>&1
*/5 * * * * librenms /opt/librenms/services-wrapper.py 1
Can you help ?
