nms
21 April 2021 01:15
#1
I have added several 11E devices to the network. I had to modify the yaml file to get humidity and sensor state on the devices main page. I am seeing upper and lower bound thresholds for the internal sensor but did not set them up.
Where else should I be looking to find where these mibs are configured?
Hi @nms
LibreNMS is computing thresholds when they are not provided via SNMP and configured in the YAML file.
You can disable this “guessed” values :
source: Support/Configuration.md
path: blob/master/doc/
The options shown below also contain the default values.
If you would like to alter any of these then please add your config option to `config.php`.
# Directories
```php
$config['install_dir'] = "/opt/librenms";
Set the installation directory (defaults to /opt/librenms), if you
clone the GitHub branch to another location ensure you alter this.
```php
$config['temp_dir'] = "/tmp";
The temporary directory is where images and other temporary files are
This file has been truncated. show original
https://docs.librenms.org/Developing/os/Health-Information/
system
Closed
21 July 2021 13:49
#3
