We are in the process of converting our entire MPLS network to a different provider, and I’ve noticed that most if not all of the local address are incorrect, however the peer addresses appear to be correct. In some cases the local address isn’t even address it a strange set of characters. For example one of my location is showing #0ot, and another is showing =]3.
The IPs are saved in the database in varbinary form, maybe you can try to convert/cast that to char and see what the actual entry in the database shows. From which vendor is your hardware from? Juniper?
Sorry for the delay… Cisco 2900 Series routers.
