Hello
Is there some option for monitoring BGP on Mikrotik please? I search but without luck …
Hello
The only thing I came up with was someone wrote a nagios plugin to monitor BGP with Mikrotik and it does work with LibreNMS
in ssh terminal inside librenms directory runs ./discovery.php -m bgp-peers -h -v -d
The problem is that Mikrotik does not support snmp monitoring of BGP. It has been requested since at least 2003 but has still not been implemented. Work arounds right now require ssh or api access.
