Hi
Our billing graphs are reporting about 10% more traffic then our provider is reporting to us. In the past we had our own tool which was getting the counters from the switch port and this was the same as our provider was reporting so it seems there is a difference in LibreNMS. Are there some configuration options to make concerning the billing module what can explain the difference?
Anybody else encountering this issue also?
[email protected]:~$ ./validate.php
Component | Version |
LibreNMS | 1.57 |
DB Schema | 2019_10_03_211702_serialize_config (145) |
PHP | 7.2.17-0ubuntu0.18.04.1 |
MySQL | 10.1.38-MariaDB-0ubuntu0.18.04.1 |
RRDTool | 1.7.0 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.9.1
