Billing module delta issue after device recovers from outage
  • Billing monitor of a device that has semi-regular drop outs
  • Devices being monitored specifically are Mikrotik RouterBoard of various firmware
We have an issue where the usage delta is massive after a monitored device’s connection is restored after an outage. In our billing module we are using quota not CDR.
I have checked the SQL data and have found that when the device is unreachable it is recording a 0 for that check-in rather than what I would expect to be NaN to avoid the delta split between 0 and it’s current counter.
Is this behaviour expected, or is there a setting we may have misconfigured?
See below for SQL export and a custom SNMP walk for the OID
| bill_id | timestamp | period | delta | in_delta | out_delta |
| 5 | 2023-08-21 09:25:03 | 301 | 57151 | 24517 | 32634 |
| 5 | 2023-08-21 09:20:02 | 299 | 58237 | 24903 | 33334 |
| 5 | 2023-08-21 09:15:03 | 1 | 760 | 380 | 380 |
| 5 | 2023-08-21 09:15:02 | 300 | 56611 | 24247 | 32364 |
| 5 | 2023-08-21 09:10:03 | 300 | 583675333 | 222498727 | 361176606 |
| 5 | 2023-08-21 09:05:03 | 300 | 0 | 0 | 0 |
| 5 | 2023-08-21 09:00:03 | 300 | 0 | 0 | 0 |
| 5 | 2023-08-21 08:55:03 | 300 | 0 | 0 | 0 |
| 5 | 2023-08-21 08:50:03 | 301 | 0 | 0 | 0 |
| 5 | 2023-08-21 08:45:02 | 299 | 0 | 0 | 0 |
| 5 | 2023-08-21 08:40:03 | 325 | 115426 | 41722 | 73704 |
| 5 | 2023-08-21 08:35:02 | 299 | 115426 | 41722 | 73704 |
| 5 | 2023-08-21 08:30:03 | 300 | 57328 | 22030 | 35298 |
| 5 | 2023-08-21 08:25:03 | 300 | 57681 | 25067 | 32614 |
| 5 | 2023-08-21 08:20:03 | 300 | 57823 | 24853 | 32970 |
| 5 | 2023-08-21 08:15:03 | 300 | 57151 | 24517 | 32634 |
| 5 | 2023-08-21 08:10:03 | 301 | 59319 | 25471 | 33848 |
| 5 | 2023-08-21 08:05:02 | 299 | 56231 | 24057 | 32174 |
| 5 | 2023-08-21 08:00:03 | 300 | 57703 | 24793 | 32910 |
And the SNMP walk with the OID counter current value (no delta calculation done).
20230821-08:54   000.207179 GB           000.336307 GB
20230821-08:55
20230821-08:56
20230821-08:57
20230821-08:58
20230821-08:59
20230821-09:00
20230821-09:01
20230821-09:02   000.207187 GB           000.336332 GB
20230821-09:03   000.207190 GB           000.336335 GB
20230821-09:04   000.207192 GB           000.336338 GB
20230821-09:05   000.207194 GB           000.336341 GB
20230821-09:06   000.207208 GB           000.336360 GB
20230821-09:07   000.207210 GB           000.336362 GB
20230821-09:08   000.207212 GB           000.336365 GB
20230821-09:09   000.207215 GB           000.336368 GB
20230821-09:10   000.207217 GB           000.336371 GB
20230821-09:11   000.207230 GB           000.336389 GB
Bump. Has anyone run into this issue or have and insights that may be helpful?
