We have vserver entry that was removed from the configuration in the Netscaler but Librenms still see them as their last status.
Polling module see that those vserver aren’t there anymore because it put an “-” before the line:
-vs_cxapps.interne.ssq.ca_def_dev_httpSQL[DELETE FROM netscaler_vservers
WHERE vsvr_id
= ? [{“vsvr_id”:2552,“device_id”:22,“vsvr_name”:“vs_xxxx.xxxx.xxx_def_dev_http”,“vsvr_ip”:“0.0.0.0”,“vsvr_port”:80,“vsvr_type”:“http”,“vsvr_state”:“up”,“vsvr_clients”:0,“vsvr_server”:0,“vsvr_req_rate”:0,“vsvr_bps_in”:0,“vsvr_bps_out”:0}] 0.2ms]
If we enable mysql queries logging we do see this in the log:
21 Prepare DELETE FROM `netscaler_vservers` WHERE `vsvr_id` = ?
21 Execute DELETE FROM `netscaler_vservers` WHERE `vsvr_id` = 'Array'
21 Close stmt
Looks like something being missed between the polling modules and mysql because the “Array” value isn’t being translated in the vsrv_id.
The auto creation of new vserver works as expected.
Trying to figure out the issue myself, but asking for help from the community.
Thanks!
Validate.php
Component | Version |
LibreNMS | |
DB Schema | 271 |
PHP | 7.2.13 |
MySQL | 10.3.11-MariaDB |
RRDTool | 1.4.8 |
SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.8.3
fatal: Not a git repository (or any parent up to mount point /app)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
usage: git diff [–no-index]
You can switch back to master with git checkout master
[FAIL] You need to run this script as root or librenms
sudo chown -R librenms:librenms /app/librenms
sudo setfacl -d -m g::rwx /app/librenms/rrd /app/librenms/logs /app/librenms/bootstrap/cache/ /app/librenms/storage/
sudo chmod -R ug=rwX /app/librenms/rrd /app/librenms/logs /app/librenms/bootstrap/cache/ /app/librenms/storage/
Files:
/app/librenms/storage/framework/views/29721d4721d98a0c1e85451cc3afa43c
