[L8-problem solved] Wrong credentials are causing ErrorException
when you enter wrong credentials at WUI login
you’re thrown to the " Whoops, looks like something went wrong. Check your librenms.log."-page.
No hint is given on “wrong credentials” until you hit the -button of your browser.
Tested with chrome and firefox.
Blockquote
LibreNMS | 1.43-92-ge81a1fc
DB Schema | 267
PHP | 7.1.21
MySQL | 5.5.60-MariaDB
RRDTool | 1.4.8
SNMP | NET-SNMP 5.7.2
[OK] Composer Version: 1.7.2
Can somebody please confirm?
Thank you!
Best regards,
-awaum
What auth method? Mine just says “Invalid Credentials”
Perhaps post the error message from librenms.log?
sorry for leaving this out.
$config[‘auth_mechanism’] = “active_directory”;
We’re using LDAP over TLS.
The messages are here:
https://p.libren.ms/view/0d0b8968
There are about a hundred posts about that here.
Run ./validate.php and fix the given issues.
Hi Murrant,
thank you for your reply!
Sorry for wasting your time by ignoring problems reported by ./validate.php
I will never do this again! (promised!)
Guys,
I was igoring these warning lines ./validate.phhp reported:
Modified Files:
includes/definitions/sonicwall.yaml
mibs/sonicwall/SONICWALL-FIREWALL-IP-STATISTICS-MIB
mibs/sonicwall/SONICWALL-SMI
These did not look important to me and not relevant to the problem I observed.
However, actually these did prevent (parts) of automatic updates!
./scripts/github-remove -d
fixed the issue, then ran
→ ./daily.sh
Now the “BUG” reported above is gone!
I’m telling this to other “ignorant guys” like me :slight_smile:
Thank you!
