How would one get info from the radios, which I can assure you are present Cera OS 9 pulls data fine.
Hi @signa
Right now, the code seems to search all interfaces that include βRadioβ in their name. (ifDescr to be precise). This way of doing is not very efficient and obvisously does not work in your setup.
I would suggest that you check the code existing in includes/polling/os/ceraos.inc.php
You can then adapt this file and submit a pull request to enhance LibreNMS for all other users
The best would be to find a proper OID to get this number (in a single SNMP request).
