ok, as @murrant asked, i will post this in forum
so my question was
is there any way to avoid annoying styleci errors when making a PR ?
and answer was
lnms dev:check style
, the only problem is the offline check is not 100% consistent.
so i tried this command on some old code i make on my old LNMS install and it is worked
PHP files with faulty code was detected and rewritten so, yes, looks lite it will help in future
