I installed check_mssql_health on LibreNMS running with Ubuntu 16.04 and I have a little problem.
With the commande line the plugin works fine, I get the correct result. Exemple testing conncetion.
OK - 0.01 seconds to connect as USER | ‘connection_time’=0.01;1;5;;
I tried different --mode like list all databases or current users and have the correct result.
But when I try to use the check_mssql_health on LibreNMS I get the instructions info.
I also used check_mssql_server.py and check_mssql_database.py and they both run fine via terminal command and LibreNMS, but I’m having issues with this one.
Finally got it working. In parameters I used --server=server --username=“domain\user” --password=“password”
Instead of
–server=server --username=‘domain\user’ --password=‘password’
