I’ve configured one service for radius check. Cron job execute this check within “/opt/librenms/services-wrapper.py 1”.
When “/opt/librenms/services-wrapper.py 1” runs from cron job, check_radius service will return Auth Error. However if I start “/opt/librenms/services-wrapper.py 1” manually, check_radius service return Auth OK.
Anyone an idea what can be reason for this issue?
Output of ./validate.php
LibreNMS | 22.2.1-12-g42c16de54
DB Schema | 2022_02_03_164059_increase_auth_id_length (235)
PHP | 7.4.13
Python | 3.6.8
MySQL | 10.3.17-MariaDB
RRDTool | 1.7.0
SNMP | 5.8
[OK] Composer Version: 2.2.7
[WARN] Your install is over 24 hours out of date, last update: Sun, 06 Mar 2022 18:52:50 +0000
Modified Files:
config/hashing.php
config/tinker.php
Following is debug output when wrapper has been started from cron job
Nagios Service - 57
Request: '/usr/lib64/nagios/plugins/check_radius' '-H' 'MY_RADIUS_SERVER_IP' '-F' '/etc/radiusclient/radiusclient.conf' '-u' 'RADIUS_USERNAME' '-p' 'USERS_PASSWORD'
Perf Data - None.
Response: Auth Error
/opt/librenms/check-services.php 2022-03-08 20:00:30 - 1 services polled in 0.020 secs
And following is debug output when wrapper has been started manually
Nagios Service - 57
Perf Data - None.
Response: Auth OK
/opt/librenms/check-services.php 2022-03-08 20:12:45 - 1 services polled in 0.034 secs
