since a long time I have this problem when I run
./validate.php
It always reports:
Files:
/opt/librenms/html/plugins/Weathermap/output
/opt/librenms/html/plugins/Weathermap/output/.gitignore
/opt/librenms/html/plugins/Weathermap/output/index.php
/opt/librenms/html/plugins/Weathermap/output/file1.png
/opt/librenms/html/plugins/Weathermap/output/file1.html
/opt/librenms/html/plugins/Weathermap/output/file2.png
/opt/librenms/html/plugins/Weathermap/output/file2.html
/opt/librenms/html/plugins/Weathermap/configs
/opt/librenms/html/plugins/Weathermap/configs/.htaccess
/opt/librenms/html/plugins/Weathermap/configs/file1.conf
/opt/librenms/html/plugins/Weathermap/configs/file2.conf
/opt/librenms/html/plugins/Weathermap/configs/index.php
Now after I followed the instructions in
[Cannot declare class Weathermap, because the name is already in use - After Update - #16 by Kevin_Krumm](http://Cannot declare class Weathermap…)
I was hoping that this error message would disappear, but it didin’t…:
I did the “git clone” as “librenms”,
so everything under /opt/librenms/Weathermap is owned by “librenms:librenms”,
except everything under
/opt/librenms/Weathermap/configs
and also
/opt/librenms/Weathermap/output
which is owned by “nginx:librenms”.
Please help me to identify the problem.
Is validate.php not taking into account that the last two paths need to be writable by the webserver…
or am I doing something wrong?
Thank you!
-awaum
