My problem is that when i create the alert rule, i can choose it, but librenms show only radio button yes or no, i i don’t know how to show a textbox to set my percent.
Sorry if this question is already answer, i can’t find anything…
My next problem, is a need to compare rate with other field, in my case: wireless_sensor.sensor_current, is there away to do this in GUI?, for the moment i’m trying to build a custom SQL.
DId you ever managed to make this work using Murrant’s solution?
I’m facing the same issue but appeding _perc or putting rate in the name is not helping.
