Daily.sh Error
Recently updated our Libre server and ran into some errors. After much reading and asking coworkers for advice, it is finally down to one error that we cannot seem to tackle. The daily.sh command gives the following results:
warning: unable to access ‘/root/.config/git/ignore’: Permission denied
error: The following untracked working tree files would be overwritten by merge:
app/Http/Controllers/Auth/VerificationController.php
config/hashing.php
config/logging.php
config/tinker.php
html/svg/403.svg
html/svg/404.svg
html/svg/500.svg
html/svg/503.svg
includes/definitions/discovery/nokia-isam.yaml
includes/definitions/nokia-isam.yaml
includes/discovery/mempools/nokia-isam.inc.php
includes/discovery/sensors/dbm/nokia-isam.inc.php
includes/discovery/sensors/pre-cache/nokia-isam.inc.php
includes/discovery/sensors/state/nokia-isam.inc.php
includes/discovery/sensors/temperature/nokia-isam.inc.php
includes/polling/mempools/nokia-isam.inc.php
includes/polling/os/nokia-isam.inc.php
includes/polling/ports/nokia-isam.inc.php
includes/polling/sensors/state/eds.inc.php
includes/polling/sensors/temperature/eds.inc.php
mibs/nokia/ASAM-ALARM-MIB
mibs/nokia/ASAM-EQUIP-MIB
mibs/nokia/ASAM-SYSTEM-MIB
mibs/nokia/ASAM-TC-MIB
mibs/nokia/ITF-MIB
mibs/nokia/ITF-MIB-EXT
mibs/nokia/SFP-MIB
mibs/nokia/SYSTEM-MIB
resources/js/app.js
resources/js/bootstrap.js
resources/js/components/ExampleComponent.vue
resources/sass/_variables.scss
resources/sass/app.scss
tests/data/nokia-isam.json
tests/snmpsim/nokia-isam.snmprec
Please move or remove them before you can merge.
Aborting
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
and validate.php gives this:
LibreNMS 1.48.1-32-g25954cc
DB Schema 2019_01_16_195644_add_vrf_id_and_bgpLocalAs (131)
PHP 7.2.15-1+ubuntu16.04.1+deb.sury.org+1
MySQL 10.0.38-MariaDB-0ubuntu0.16.04.1
RRDTool 1.5.5
SNMP NET-SNMP 5.7.3
[OK] Composer Version: 1.8.4
[WARN] Your install is over 24 hours out of date, last update: Mon, 11 Feb 2019 20:17:50 +0000
I am still new to Linux and learning more daily, but this one has several people stumped. Any assistance would be greatly appreciated.
I started getting the same issue on my Ubuntu 18.04 install. I have tried changing the permissions and running “./scripts/github-remove -d” and so far nothing is able to fix it.
This is what I have done to remediate this.
Make a backup first, validate config and fix errors, and then fix git.
STEPS:
cd /opt
sudo rsync --exclude=librenms/logs -avh librenms librenms.bak #Make backup
./validate.php
Fix issues
./validate.php
Try github-remove -s … it fails on my host
./scripts/github-remove -s
So I tried a quick manual fix
git reset --hard HEAD
git clean -f -d --dry-run
#INSPECT above output!
WATCH OUT!!##
##git clean -f -d
git pull
OUTPUT:
[[email protected] ~ ]$ ./validate.php
PHP 7.1.26
MySQL 5.5.60-MariaDB
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
[FAIL] Time between this server and the mysql database is off
Mysql time 2019-02-14 19:37:22
PHP time 2019-02-14 18:37:22
[FAIL] You have no timezone set for php.
Modified Files:
.editorconfig
.gitignore
.travis.yml
LibreNMS/Alert/Transport/Alertmanager.php
LibreNMS/Alert/Transport/Elasticsearch.php
LibreNMS/Alert/Transport/Mattermost.php
LibreNMS/Util/Laravel.php
LibreNMS/Util/ModuleTestHelper.php
LibreNMS/Validations/Database.php
app/Console/Kernel.php
app/Exceptions/Handler.php
app/Http/Controllers/Auth/RegisterController.php
app/Http/Kernel.php
app/Http/Middleware/EncryptCookies.php
app/Http/Middleware/TrimStrings.php
and 67 more…
sudo chown -R librenms:librenms /usr/local/opt/librenms
sudo setfacl -d -m g::rwx /usr/local/opt/librenms/rrd /usr/local/opt/librenms/logs /usr/local/opt/librenms/bootstrap/cache/ /usr/local/opt/librenms/storage/
sudo chmod -R ug=rwX /usr/local/opt/librenms/rrd /usr/local/opt/librenms/logs /usr/local/opt/librenms/bootstrap/cache/ /usr/local/opt/librenms/storage/
Files:
/usr/local/opt/librenms/storage/framework/views/26378f14e676770383128963b26d6510
Fix issues the above issues
Re-run ./validate.php
PHP 7.1.26
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
Mysql time 2019-02-14 19:38:25
PHP time 2019-02-14 18:38:25
Modified Files:
.editorconfig
.gitignore
.travis.yml
app/Http/Kernel.php
and 67 more…
It will tell you to use ./scripts/github-remove but I have not active GIT account
[[email protected] ~ ]$ ./scripts/github-remove -h
usage: github-remove [-h] (-d | -s | -r) [-v]
optional arguments:
-h, --help show this help message and exit
-d, --discard Discard all changes clean extra files
-s, --save Save and remove changes by stashing them. (git stash)
-r, --restore Attempt to restore saved changes (git stash pop)
-v, --vendor Also discard changes to ./vendor (requires --discard)
[[email protected] ~ ]$ ./scripts/github-remove -s
*** Please tell me who you are.
Run
git config --global user.email "[email protected]"
git config --global user.name “Your Name”
to set your account’s default identity.
Omit --global to set the identity only in this repository.
fatal: empty ident name (for [email protected]) not allowed
Cannot save the current index state
[[email protected] ~ ]$ git reset --hard HEAD
HEAD is now at 25954cc JunOS: Added Virtual Chassis Member Role Sensor (#9783)
RUN THIS AND INSPECT THIS
[[email protected] ~ ]$ git clean -f -d --dry-run
[[email protected] ~ ]$ git pull
./daily.php
Why are you trying to stash that… if you want to stash of course you need account.
Run with the -d and then update
This worked, thank you very much!
Correction This cleared the errors from daily.sh, but crashed the Apache server. The removed files had to be restored from the backup to get it back online, so the error has returned.
That’s probably because you have an apache rights issue…
Updating 25954cc…2eac72d
error: unable to create file storage/framework/cache/data/.gitignore (Permission denied)
Make sure you fix all the issues validate.php is telling, so also the:
  • chown
  • chmod
  • setfacl
So in the end it boils down to:
./validate.php
(FIX all chown chmod setfacl etc)
./validate.php
git pull
If that works verify with
./daily.sh
Validate.php does not give me any permission or ownership errors. Only the database schema and my install being more than 24 hours out of date.
Uhm… restored from backup?
You forgot to do the:
cd /opt
./validate.php
Ok… show us the ./validate.php and ./daily.sh pls…
[email protected]:/opt/librenms# ./validate.php
DB Schema 2019_02_10_220000_add_dates_to_fdb (132)
RRDTool 1.5.5
SNMP NET-SNMP 5.7.3
[WARN] Your database schema has extra migrations (2019_02_10_220000_add_dates_to_fdb). If you just switched to the stable release from the daily release, your database is in between releases and this will be resolved with the next release.
[email protected]:/opt/librenms# ./daily.sh
config/hashing.php
config/logging.php
config/tinker.php
html/svg/403.svg
html/svg/404.svg
html/svg/500.svg
html/svg/503.svg
mibs/nokia/ITF-MIB
mibs/nokia/SFP-MIB
resources/js/app.js
Aborting
Cleaning up DB OK
So… after you first make a copy with rsync:
  • cd /opt
  • sudo rsync --exclude=librenms/logs -avh librenms librenms.bak #Make backup
(Don’t forget that step now…)
What does the following give you?
  • cd /opt/librenms
  • ./scripts/github-remove -d
  • ./validate.php
  • ./daily.sh
