Could use some help. I recently ran an upgrade from 1.47 to 1.53, and while the upgrade itself seemed to go without much issue, I am now unable to see any of my previous dashboards, nor can I edit to create new ones. I can create a new empty dashboard, but when I go to edit to add a new widget, I am unable to do so, it instead reverts back to the default dashboard with no changes being saved.
IF I then make an attempt again, it instead is unresponsive and just sits there, not actually making any changes no matter the widget selected.
I have attempted in Safari, Brave, and Firefox, all with the same results.
LibreNMS is running in a docker-compose stack, with mariadb as the SQL backend.
I have no issues with polling or alerting, and all devices seem to be responding fine.
Validate.php results:
[email protected]:/opt/librenms# ./validate.php
Component | Version |
LibreNMS | 1.53-1-g8ad55b55b |
DB Schema | 2019_05_30_225937_device_groups_rewrite (135) |
PHP | 7.3.5-1+ubuntu18.04.1+deb.sury.org+1 |
MySQL | 10.3.12-MariaDB-1:10.3.12+maria~bionic |
RRDTool | 1.7.0 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.8.6
If anyone has any recommendations or simple things i’m overlooking, I would really appreciate it!
