It had some errors before
[2019-08-12 08:00:23] production.ERROR: SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry '456-116' for key 'device_ifIndex' (SQL: UPDATE `ports` set `ifIndex`=116,`poll_time`=1565596822,`poll_prev`=1559944226,`poll_period`=5652596,`ifLastChange`=92821316,`ifInOctets`=60689059588,`ifInOctets_prev`=781126467894,`ifInOctets_rate`=0,`ifInOctets_delta`=-720437408306,`ifOutOctets`=60692684811,`ifOutOctets_prev`=781198118814,`ifOutOctets_rate`=0,`ifOutOctets_delta`=-720505434003,`ifInErrors`=1,`ifInErrors_prev`=0,`ifInErrors_rate`=1.7690986583863E-7,`ifInErrors_delta`=1,`ifOutErrors`=0,`ifOutErrors_prev`=0,`ifOutErrors_rate`=0,`ifOutErrors_delta`=0,`ifInUcastPkts`=249190295,`ifInUcastPkts_prev`=15378888,`ifInUcastPkts_rate`=41.363544643912,`ifInUcastPkts_delta`=233811407,`ifOutUcastPkts`=249195562,`ifOutUcastPkts_prev`=15379395,`ifOutUcastPkts_rate`=41.364386734874,`ifOutUcastPkts_delta`=233816167 WHERE `port_id` = 1464759) (SQL: UPDATE `ports` set `ifIndex`=116,`poll_time`=1565596822,`poll_prev`=1559944226,`poll_period`=5652596,`ifLastChange`=92821316,`ifInOctets`=60689059588,`ifInOctets_prev`=781126467894,`ifInOctets_rate`=0,`ifInOctets_delta`=-720437408306,`ifOutOctets`=60692684811,`ifOutOctets_prev`=781198118814,`ifOutOctets_rate`=0,`ifOutOctets_delta`=-720505434003,`ifInErrors`=1,`ifInErrors_prev`=0,`ifInErrors_rate`=1.7690986583863E-7,`ifInErrors_delta`=1,`ifOutErrors`=0,`ifOutErrors_prev`=0,`ifOutErrors_rate`=0,`ifOutErrors_delta`=0,`ifInUcastPkts`=249190295,`ifInUcastPkts_prev`=15378888,`ifInUcastPkts_rate`=41.363544643912,`ifInUcastPkts_delta`=233811407,`ifOutUcastPkts`=249195562,`ifOutUcastPkts_prev`=15379395,`ifOutUcastPkts_rate`=41.364386734874,`ifOutUcastPkts_delta`=233816167 WHERE `port_id` = 1464759)#0 /opt/librenms/includes/polling/ports.inc.php(914): dbUpdate(Array, 'ports', '`port_id` = ?', Array)
#1 /opt/librenms/includes/polling/functions.inc.php(309): include('/opt/librenms/i...')
#2 /opt/librenms/poller.php(173): poll_device(Array, false)
#3 {main}
I’ve deleted and readded the device, after that, there are no errors in the librenms.log only reports about pooler.php
/opt/librenms/discovery.php new 2019-08-14 08:25:01 - 0 devices discovered in 0.002 secs
/opt/librenms/poller.php 77 2019-08-14 08:25:10 - 1 devices polled in 8.036 secs
./validate.php
LibreNMS | 1.54-33-g67376e2
DB Schema | 2019_07_09_150217_update_users_widgets_settings (140)
PHP | 7.2.21
MySQL | 5.5.60-MariaDB
RRDTool | 1.6.0
SNMP | NET-SNMP 5.7.2
[OK] Composer Version: 1.9.0
