In the process of tracking down another issue, I’ve noticed that I have some issues with my database schema.
# ./validate.php
LibreNMS | 1.51-18-geb8600e
DB Schema | 2019_02_10_220000_add_dates_to_fdb (132)
PHP | 7.1.8
MySQL | 5.7.24
RRDTool | 1.4.8
SNMP | NET-SNMP 5.7.2
[OK] Composer Version: 1.8.5
[FAIL] Database: incorrect column (ports/ifInUcastPkts_delta)
[FAIL] Database: incorrect column (ports/ifOutUcastPkts_delta)
[FAIL] Database: incorrect column (ports/ifInOctets_delta)
[FAIL] Database: incorrect column (ports/ifOutOctets_delta)
[FAIL] We have detected that your database schema may be wrong, please report the following to us on Discord (https://t.libren.ms/discord) or the community site (https://t.libren.ms/5gscd):
SQL Statements:
ALTER TABLE `ports` CHANGE `ifInUcastPkts_delta` `ifInUcastPkts_delta` bigint(20) unsigned NULL ;
ALTER TABLE `ports` CHANGE `ifOutUcastPkts_delta` `ifOutUcastPkts_delta` bigint(20) unsigned NULL ;
ALTER TABLE `ports` CHANGE `ifInOctets_delta` `ifInOctets_delta` bigint(20) unsigned NULL ;
ALTER TABLE `ports` CHANGE `ifOutOctets_delta` `ifOutOctets_delta` bigint(20) unsigned NULL ;
However, when I try to fix the schema, it doesn’t work.
mysql> ALTER TABLE `ports` CHANGE `ifInUcastPkts_delta` `ifInUcastPkts_delta` bigint(20) unsigned NULL ;
ERROR 1264 (22003): Out of range value for column 'ifInUcastPkts_delta' at row 15422
mysql> ALTER TABLE `ports` CHANGE `ifOutUcastPkts_delta` `ifOutUcastPkts_delta` bigint(20) unsigned NULL ;
ERROR 1264 (22003): Out of range value for column 'ifOutUcastPkts_delta' at row 15422
mysql> ALTER TABLE `ports` CHANGE `ifInOctets_delta` `ifInOctets_delta` bigint(20) unsigned NULL ;
ERROR 1264 (22003): Out of range value for column 'ifInOctets_delta' at row 15225
mysql> ALTER TABLE `ports` CHANGE `ifOutOctets_delta` `ifOutOctets_delta` bigint(20) unsigned NULL ;
ERROR 1264 (22003): Out of range value for column 'ifOutOctets_delta' at row 15225
mysql>
My unscientific conclusion is that this is because there’s a negative delta value in those rows which of course won’t work with an unsigned integer. Any suggestions?
