DB Schema | Not Connected and Database | Not Connected after php81 upgrade
hello,
after upgrading on 2 other server with no issue, my third server throws problems.
  1. the ‘my.cnf’ files was empty, fixed that with the ‘my.cnf.rpmsave’ backup
  2. .env file is fine
  3. permissions are correct in all directory’s as i ran -
  1. Database appears to be intact, i ran a repair and all is “ok”
here is output of ‘validate.php’
In config.php line 44:
  Undefined constant "discovery_modules"
LibreNMS  | 22.9.0-3-g06c361c
DB Schema | Not Connected (0)
PHP       | 8.1.11
Python    | 3.6.8
RRDTool   | 1.4.8
SNMP      | 5.7.2
[OK]    Composer Version: 2.4.2
bash-4.2$
output of ‘daily.sh’
bash-4.2$ ./daily.sh
PHP Fatal error: Uncaught Error: Undefined constant “discovery_modules” in /opt/librenms/config.php:44
Stack trace:
#0 Command line code(1): include()
#1 {main}
thrown in /opt/librenms/config.php on line 44
Stack trace:
#1 {main}
Updating SQL-Schema /opt/librenms/daily.sh: line 62: /daily.log: Permission denied
/opt/librenms/daily.sh: line 65: /daily.log: Permission denied
/opt/librenms/daily.sh: line 66: /daily.log: Permission denied
OK
Cleaning up DB /opt/librenms/daily.sh: line 62: /daily.log: Permission denied
OK
bash-4.2$
line 44 of /opt/librenms/config.php -
$config[discovery_modules][discovery-arp] = 1;
what am i missing?
I stalked around for a similar issue and none of those fixes helped.
Thanks in advance
-Mike
That should be quoted I’d have thought - are the other things in config.php quoted?
$config['discovery_modules']['discovery-arp'] = 1;
Cut and paste it from here if unsure: Discovery Support - LibreNMS Docs
Thank you, that fixed it. missing the single quote.
Thanks!
-Mike
