i will look into that - so far ive set the values static
Hey All,
i have quiet the same issue - The values for various devices are totally off.
For example my QNap NAS in a small branch office:
Every now and then (once per week?) the values are reset. I edit the device and lower the values of the fan sensors, a week later they are set back to a ways to high value. Result: I’m getting alarms for too low fan sensor values (which are still very healthy).
any advice?
Hay All
We have similar situation. LibreNMS reported that Cisco device temperature sensor over limit.
Found that there is incorrect values on Health settings. Corrected manually but next day wrong values back again.
Hi
Just want to check if you been able resolve mentioned issue?
Hi - I’m facing same issue - looks like you also need to set in MySQL sensors table the column sensor_custom to Yes then it shouldn’t overwrite them - as if its set to No it seems to re-read/guess them at certain points
