Define standard subject line containing CPU load in LibreNMS
Hello All,
I am trying to define standard subject line (followed by organization in previous monitoring tool) for LibreNMS with the alerting.
So far all works.
Question:
  1. Is there a way to edit the title of the messages?
Expected subject for mail as per previous monitoring tool is,
WARNING : My server name : CPU load : WARNING
eg.
WARNING : MYDB01 : Load : 19.73 16.09 11.49 : 19.73 15 : WARNING
  1. How i can display CPU usage, Memory Usage, Disk Usage in mail body. (I mean output of w, free, df command) ?
Please suggest.
Yes you can edit the subject ā€œAlert titleā€ within your Alert templates with placeholders like
WARNING : {{ $alert->sysName }} : CPU load : WARNING
or
WARNING : {{ $alert->hostname }} ( {{ $alert->sysName }} ) : CPU load : WARNING
i think if the data is in an array then maybe you can’t put it in your subject as they are part of the for loop in your template to iterate through each item. Your possibly interested in $value['processor_usage'] for CPU, as for storage and memory, see the examples in here https://docs.librenms.org/Alerting/Templates/
Hello All
@Chas, Thanks for help.
My query is resolved.
Here, I have used PHP query to display CPU load in ā€œAlert Titleā€ within ā€œAlert Templateā€.
My requirement was
eg.
Solution applied
WARNING : CPU utilization : {{ strtoupper($alert->sysName) }} : <?php echo `w | head -1 | awk '{ print "CPU"" "$8" "$9" "$10" "$11" "$12 }'` ?> : WARNING
Output:
WARNING : CPU utilization : MYDB01 : CPU average: 1.01, 1.14, 1.05 : WARNING
