Deprecated notification voor NTP hex values Cisco
I have multiple logwarnings about a depricated PHP:
PHP Deprecation(8192): Invalid characters passed for attempted conversion, these have been ignored in /opt/librenms/includes/polling/ntp/cisco.inc.php:67
And the lines 70 and 74.
This is about the SNMP cntpPeersOffset value Hex-STRING, which is containing spaces:
00 00 00 00
The log warning is about hexdec(‘00 00’).
LibreNMS  | 26.8.0 (2026-08-17T17:56:40+02:00)
DB Schema | 2026_07_30_162514_add_device_refresh_config_permission (397)
PHP       | 8.4.24
Python    | 3.9.2
Database  | MariaDB 10.5.19-MariaDB-0+deb11u2
SNMP      | 5.9
[OK]    Composer Version: 2.10.2
[OK]    Python wrapper cron entry is not present
[OK]    Redis is functional
[WARN]  IPv6 is disabled on your server, you will not be able to add IPv6 devices.
[INFO]  Checking RRD files took too long, check skipped. You can run lnms maintenance:rrd-step all to check and fix all rrd files.
Not a major problem but maybe something to be fixed in the next release.
Thank you.
