Since a while back the popup that shows up when hovering over the device name on a device page seems to be themed according to “prefers-color-scheme”, ignoring the chosen librenms theme “light”. If I change color-scheme in windows to light, it’ll look correct.
I’m assuming it has something to do with this part in resources/views/layouts/librenmsv1.blade.php
<script>
// Apply color scheme
if ('{{ LibreNMS\Config::get('applied_site_style', 'light') }}' === 'dark' || window.matchMedia('(prefers-color-scheme: dark)').matches) {
document.documentElement.classList.add('tw-dark')
} else {
document.documentElement.classList.remove('tw-dark')
</script>
